1999 F-350 primary fuel pump won't run
It should have a relay. The current draw is a little more than what runs through the PCM. I am not so sure about diesels, but if you have a gas motor, you have a return fuel system. I'd suspect your FP relay to be under the hood, you can check for voltage across the coil connections and voltage on the input/output connections. However if the engine is running, the coil should be energized and passing current.
Thanks for the replies! Its a 1999 Superduty 7.3 Turbo Diesel 4X4
I finally found the relay .There's a small relay block under dash behind the stereo I used diagram to figure out that I had no key on power. Traced the wire back through firewall and found it broke under hood . Repaired wire and it is up and running great!
sjg5698
1999 to 2016 Super Duty
07-05-2010 07:29 PM
galaxian
10-21-2003 08:55 AM
