1992 f-150 blower works on high only????
Under the hood in the heater box on the pass. side firewall there is a plug with I believe about 4 thicker wires. What it plugs into is bolted into the heater/blower box with two small bolts. This is what controls your heater speeds and when they get older they like to go out. It is in the heater box because to reduce the speed of the blower the current has to run threw coiled wires which get hot. The coiled wires are what corrode and fall apart over time and make the blower not work on reduced speeds.
If someone has a picture it would help a bunch I am sure.
Here is what you are looking for, NAPA part # ECH BR223 http://partimages.genpt.com/partimages/274106.jpg
and you might also need this as mentioned earlier. NAPA Part # ECH EC4 http://partimages.genpt.com/partimages/98682.jpg
Good luck...
Good luck...
pursable
02-05-2004 08:54 AM
