Grease Hub bearing assymbly wheel bearings
I'm sure someone has mentioned this but I'll throw it out there anyway.
I just installed four ball joints, pass. side bearing assy and complete axle shaft, and seals,, and warn hubs. (I nearly had to sell every fluid my body makes)
Well, I am now taking apart old axle just to see how.
And Im takeing apart wheel bearing now and stoped to ask you something I thought of.
MY question: What if we made a zerk fitting that screws into the abs hole on the hub to shoot a little grease in form time to time?
Will the grease get to both sets of the wheel bearings?
One thing I know for sure is I will be pulling the dang hubs off to grease the inside axle support bearing every 40K miles
to all the great people here and thanks for all the info I'v learned this year and before that too!!
Ryan
Ryan
Update, I pulled bearing assy. apart and it seems grease will go to both bearings. I wonder If the grease will affect the sending unit?
Anyway, at 70K miles on the bearings, they had plenty of lube left, just a dry axle support bearing.
I'm going to start welcoming the new year now,
Ryan signing off
Good night
Ryan signing off
Good night
I have been doing this for quite some time - since replacing both front hub assemblies a few years back.
Once a year I lube these hubs by inserting an old rubber spark plug boot over my grease gun hose and the smaller end fits snugly into the ABS sensor hole. I then pump a shot or two of grease and rotate several times. Repeat this several times until the rotation stiffness is close to the original bearing feel. I have not noticed any problem with the ABS sensor and the grease - i.e. No ABS codes.
Too much grease will force it out around the inner hub assembly seal - not good.
I have approx. 200k miles on the second set of hub bearings using the lube method.
Good luck,
Good luck,
Allright Scott, thanks for the drawing. That is kinda what I was thinking. Its time to fire up the lathe
Wow, 200k on the bearings! Thats what I'm talken bout.
What is the best grease to use?
I have some lightblue colored stuff in my gun now. I think it might be synthetic, i don't remember. Seems to work for all the joints just fine.
Thanks for the help.
Lube on,
Ryan
Lube on,
Ryan
Lube on,
Ryan
Lube on,
Ryan
