Going with after market switches??
Received 4,135 Likes
on
If I use aftermarket switches for wipers lights etc.,will I need to modify the hole that they go in. I want to eliminate some of the holes in the dash and need to know if those indented different shaped holes are a must or will I be able to just use round holes for the newer switches. I'm thinking that I only need the ign., lights, and wipers on the dash.
they both have long enough threaded shafts to be used without the indented hole tho..
Sam
I filled all my dash switch holes and installed my EZ Wire switches (1/2 the price of anyone else's switches) in my lower dash extention so I don't know of the bezels will fit in the stock depressions or not, but the new switches fit into a round hole with a small square notch filed in for the tab that keeps the switch from rotating when you turn it on.
At the risk of hijacking your thread, I've filled ALL my dash holes so I'm free to use whatever I want.
I've been looking for a very art deco style of ***** but haven't had much luck yet. I really don't want the expense of having them machined for me.....so if anyone knows of a source for nice art deco style (i.e. bee hive or other similar designs) *****, plse let me know.
Now I'll get back to filling the 120 GB Ipod I got for Xmas.....
Thanks,
Thanks,
Thanks,
Thanks,
that says to search for "****" and "hotrod" but NOT any entries that contain ("shift","shifter" or "dipstick").. you can do it in one clause too
-(shift, shifter, dispstick)
the use of the 'not' prefix ('-') really make searching on ebay a lot easier cause you can weed out stuff you DON'T want to see..
Sam
on
no problem ferguson777, all input is welcome, it gives us a means of stealing and running with someone else's ideas. I have seen dice used as *****
Sam,
Thank you. Thank You.
Once for that tip on how to do an Ebay search with exclusions built into it
Once for connecting me with that particular vendor.
While nothing he has on Ebay right now matches what I am after, it is apparent that he can do what I want for a not totally outrageous price.
Problem solved.
Thanks again,
Problem solved.
Thanks again,
I was also pleased that the EZ W switches (GM OEM type) have simple disk ***** with icons on them that do not protrude from the face of the panel much more than the thickness of the ****. Since the portion of the extension I am mounting them to angles back ~ 45*, I am looking at them in profile and didn't want to see a lot of shaft and ****.
Thanks,
Thanks,
ididit inc - Dress Up Kit (***** & Levers)
