99 F250 7.3L Diesel Front Crank Seal
Old 12-15-2008, 08:08 PM
mblanken881's Avatar
mblanken881
mblanken881 is offline
I have a decent sized oil leak coming out of my front crank seal. This was verified by a mechanics shop. Is this something I can change myself or should I have them do it? If so, how hard is it to do? Will I be able to find a written procedure for this somewhere? I appreciate any help. Thanks, Mike.
Old 12-15-2008, 08:11 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
Old 12-15-2008, 08:24 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
I see you have had the leak mechanic verified, but for your sake, make dang sure that's what is it. The HPOP is a much more common place to leak than the seal. Also, the CPS seal has been known to leak as well. Just make sure before you tear in to it.
Old 12-15-2008, 08:28 PM
mblanken881
What are the HPOP and CPS seals? And how do I check them? Thanks, Mike.
Old 12-15-2008, 08:29 PM
mblanken881
Originally Posted by rbaker6336
Thanks rbaker!!
Old 12-15-2008, 08:41 PM
mblanken881
This guide lists quite a few specialty tools to do this job. Which of these tools are actually required? I realize the puller is required, but besides that can I do the job with normal tools? Thanks, Mike.
Old 12-16-2008, 07:06 AM
zx250's Avatar
zx250
zx250 is offline
The HPOP is the High Pressure Oil Pump. That silver retangle thing that sits on the top front of the engine is the resevior for it. It has several seals that can leak. Look around under it and make sure it's not coming from there. The CPS is a sensor mounted on the front of the engine near the water pump. Locate and follow the only wire on the front bottom side of the engine. Have a look HERE for better location.
Old 12-16-2008, 07:41 AM
clux's Avatar
clux
clux is offline
Been there, done that. If you can get the harmonic balancer off, you can change the seal.
Old 01-08-2009, 01:32 PM
mblanken881
This link no longer works. Does anybody know of another place that has service manuals for my truck?
Thanks,
Mike
Old 05-27-2009, 06:55 PM
JJFIVEOH's Avatar
JJFIVEOH
JJFIVEOH is offline
I'm familiar with the O-rings going bad on the backside of the pump, but are there seals/rings on the bottom? I just did a thorough cleaning of my engine so I have to wait until I drive it some more to find a fresh leak. But while I was cleaning it I noticed a ton of buildup behind the balancer. I was convinced it was an HPOP issue but now I'm not sure. I didn't think front seals were known for going bad on the 7.3's which is causing my confusion because all indication shows it's a seal but every search I do comes up HPOP issues.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-26-2023 11:24 PM
tubehifi
07-07-2011 09:39 PM
scotindyblue
2004 - 2008 F150
11-17-2010 09:58 PM
scotindyblue
3.8 & 4.2L V6
11-17-2010 10:23 AM
mikev
11-12-2010 02:01 PM
Quick Reply: 99 F250 7.3L Diesel Front Crank Seal
