f250 351 clutch help
Old 12-14-2008, 08:05 PM
sho's Avatar
sho
sho is offline
a friend of mine has a 94-95 f250 4x4 351 that the clutch went out on
how much of a pain is it to fix do i have to pull the motor or drop the trans or what
thanks for any help
SHO
Old 12-14-2008, 08:21 PM
bigblack302's Avatar
bigblack302
bigblack302 is offline
I say pull the motor if you have a hoist and an engine stand and use the opportunity to change the oil pan if it's rust, rear seal, oil pump, and rod bearings or any thing else you think is necessary.
I never pulled the the trans but it sure looks heavy so I would imagine that you would want a trans jack to do the job
Old 12-15-2008, 12:05 PM
sho's Avatar
sho
sho is offline
it is just a truck for wood hauling i dont think he wants to spend much
just get it so it moves and can drive in the woods
Old 12-15-2008, 12:14 PM
straightsixer's Avatar
straightsixer
straightsixer is offline
I've done it both ways, with the engine out and by pulling the tranny although on a 2WD. I'd say either way. With the engine out at least you can do most of the work standing up, unless you have access to a lift. Good luck.
Old 12-15-2008, 01:52 PM
88n94's Avatar
88n94
88n94 is offline
I would drop the transmission. You would definitely need a transmission jack, you could probably rent one. A good selection of both metric and fractional hand tools will make the job go quicker and easier. I would definitely recommend a Haynes repair manual, it gives some time saving tips and tricks.
Old 12-15-2008, 05:36 PM
guitarnik's Avatar
guitarnik
guitarnik is offline
i would pull the motor, a little less removing work but trans removal just sucks cause you cant get a lift under a truck . unless you dont have a lift, then drop the trans, when ive done it i make up a wooden bracket thingy to set on a regular floor jack. nik
Old 12-15-2008, 06:12 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I've done it on a floor jack.
But it would be better(safer) to rent one of these
There was room to set the whole tranny/ transfer case back on the crossmember once I pulled the transmission mount and floor plate.
Yanking the motor is a big pain that I would avoid if I could.
Just my 2c
F250kid
General Automotive Discussion
17
10-22-2005 01:39 AM
1984 f-250
Ford vs The Competition
30
02-18-2004 01:41 AM
lil sho
1997 - 2003 F150
10-25-2003 11:29 PM
sho02
1997 - 2003 F150
06-03-2003 01:25 AM
Quick Reply: f250 351 clutch help
