Late Model Dually Wheels on a 69 F350?
Old 09-30-2010, 05:17 AM
71 Sport Custom's Avatar
71 Sport Custom
71 Sport Custom is offline
The Coined rims should be put on your ford. The coins align the wheel to drum then inner to outer wheel. I put these on a 74 f350. took a while at the junk yards basically finding one at a time. usually 50 to 75 a wheel. The flat at the lug nut rims wont line everything up properly. Look out for van/camper duallies as these look the same but are usually 16.5s.
Old 09-30-2010, 12:24 PM
LeeShuster's Avatar
LeeShuster
LeeShuster is offline
F350 Super Camper Special SRW Wheel Specs
The 1964/72 and 1973/79 Ford Truck Parts Catalogs state:
1967/79 F350:
DOTZ1007A .. Wheel ~ 16.5" x 6" / Use with dual rear wheels only.
5.00" offset / 4 holes coined inward / 4 holes coined outward.
D1TZ1015A .. Wheel ~ 16.5" x 6" / Use with single rear wheels only.
.50" offset.
Sorry if this should be posted in the 73 - 79 Section. Does anyone know the rear wheel specifications (width, backspace, offset) of the "Super Single" Ford 16.5-inch 8-lug wheels that came on the F-350 SCS's??
Was the D1TZ1015A used on the front of the SCS, while a wider (8, 9-in wide, different part number wheel) used on the rear of the F350 Super Camper?
I would like to have some duplicates made by Stockton Wheel, but on a 16-inch diameter.
Old 10-01-2010, 06:48 AM
piney1's Avatar
piney1
piney1 is offline
I did some looking and Dodge used coined wheels up until 1993 I think.
Has anybody used the dodge wheels on a ford?
I got my trcuck home last night and it needs some tires but runs good.
1967 F350 with about a 160" wheelbase and flatbed dump.
Old 11-13-2012, 01:18 PM
68F350cowboy's Avatar
68F350cowboy
68F350cowboy is offline
I have a 68 F350 with single rear wheels. The truck has a front diff. from a 73 3/4 ton i believe, but could be off by a year or two. My question is do i have to do anything major to the front diff. in order to put dually wheels on the front of it? If so, what do i need to do?
Old 11-14-2012, 01:03 AM
RichS2659's Avatar
RichS2659
RichS2659 is offline
One question: Why? Is that using a single dually wheel or using a set of duals on the front, meaning 2 per each side? If 2 per side, it would be very impossible to steer, especially without PS, and your swapped in front axle which is probably a Dana 44 wouldn't be able to handle it.
Old 11-15-2012, 07:14 PM
68F350cowboy
No, I am talking about a single offset dually wheel on each side of the front and 2 on each side in the back.
aj88V
01-25-2015 09:07 PM
fordtruckguy98
10-27-2014 11:53 AM
69 F-350 Wrecker
06-11-2014 11:29 AM
rbmcveigh
07-08-2012 08:31 AM
Grandpas69f350
03-21-2009 04:45 PM
Quick Reply: Late Model Dually Wheels on a 69 F350?
