64 SWB molding
64 SWB molding
I am still in need of some molding for the cowls, doors, and bed sides.
Any and all help is greatly appreciated. A couple people said they had a few pieces but I never heard from them again. Someone said pm them but I am unable to do that for some reason. Email me at TUEFELHUNDEN88@AOL.COM
Thanks again, Woody
Thanks again, Woody
Welcome to FTE
Get in touch with FTE members camperspecial65 (cs65) and garbz2 for these mouldings.
I know cs65 has some, not sure if garbz2 has any remaining.
FTE member gangstaker may also have some mouldings and the grille.
All three of these members can be found in this forum.
btw: You can edit your posts for up to one hour.
You'll also need 25 posts before you can use the P/M feature.
Click on their user names for access, some may have their email listed, so you can use that instead of P/M's.
They are held on one of 2 ways...once in a while you will see both types of clips on the same truck...
One type is a push on type clip that clicks in place and the other is the more common type with the nut behind it...
Accessing them is semi easy...pull the floor/cowl vents out completely...and get a helper who has smaller strong hands/fingers as its a bit of a stretch up there for us adults with larger arms, etc...
- cs65
- cs65
I have the complete moulding set up for 65/66 long bed. And I do mean complete.
As for grills I have steel grills for 61,62,63,64 and 65 I have one 65 Aluminum.
Core supports 4 for 1961-64 f100 2wd.
PM me or contact me at
robert.regina@verizon.net
RobsRedFord
10-12-2005 07:23 PM
