air springs
air springs
I'm looking into putting a set of air springs on my 06-250 this spring coming, and wondering if there is much difference between th Airlift 5000 kit or the Firestone air kit? they're both rated for up to 5000lbs, cost about the same, mounts about the same and even looks the same. I don't have a 5th wheel hitch and tow about 8000lb travel trailer. It would be nice to smooth out the ride a bit now that winter is here, the roads are a lot rougher. Any ideas would be appreciated thanks
I just talked to a truck spring place and he suggests the Timbren ride control system, heres a link Timbren Aeon Hollow Rubber Springs they have no air and is suppose to do the same thing. Anyone hear of or know anything about this type?
The Firestones aren't going to smoothen your ride if thats what your looking to have.
They are going to stiffen up the suspension you put them on front or rear. I have air riders and they need to have 5lbs of air min. The air bags shine for heavy load situations. Empty they are harsher riding than stock susp.
Best of the season.
Best of the season.
I used the Firestone Ride-Rites with my 5th wheel; I was on the road for 2 years and had no problems, including back and forth to Alaska. I now have the Air Lift bags and carry a 5,000 pound slide in truck camper and have had no issues with the Air Lifts either.
I did buy an Air Lift compressor which the factory recommended. I didn't know until after it was installed that it is considered 'light duty'. That means it should be cycled off at least 25% of the time it is on. Run for 2 minutes, off for 30 seconds. I am not happy with that, but that was my fault for not discovering it before I installed the compressor.
I would recommend either set of bags.
I have the Firestones on my truck and I like them alot. My truck is a work truck and it weights about 11,500 lbs. every day and the bags realy helped. I keep them filled at 100 psi. all the time and they have been on for 2 years now with no problems.I just check the press. when I check the tires about once a month.
In the end though you would have to make up your mind what would be a better suited technology in your day to day use of your truck.
I should clarify what I said in that I have neither air bags or Timbrens but have been looking and asking around about both. I have had others (2) tell me they did not like air bags when the truck was empty because it created a stiffer ride. It is possible they were not running the minimum PSI when empty (I used misplaced assumption is both cases that they where). It sounds like there might not be an effect on empty ride like I thought.
I would buy firestone again without another thought. Top shelf gear and I over load them more often than not.My truck rides like a chev pavement princess with two tons in the box,when its empty there is no way I can feel 5 psi in the bags.As for a stiff ride in a 3/4 or one ton truck.... What were you expecting?Drop your tire pressure a few psi.
