Is the 5.4 a dog? 05 F-250 FX4
Compared against my old X with the V10 this thing seems to have hardly any power and is sucking fuel like there is no tomorrow, around 9.5mpg.
Company truck that my boss bought so I didn't get to test drive it, he did though. I think I even got passed by a moped last night. I have wondered this since I got it a couple weeks ago but just figured I would ask.
I guess it depends on what gear you have. My 03 SD 4x4 ex-cab 8' box was ok with the 5.4 but it had a 4.10 in it. I could pull anything but couldnt pass a gas station. It would get about 9 mpg loaded, empty, or pulling. Remeber you also have 2 less cylinders and a lot less torque too. It worked well in my F-150 with a 3.73...but I did put the Edge Evolution on it and that really woke it up.
Sarge
Sarge
I have an '07 with 3.73 gears. (See sig and pic) Driving unloaded in the highway I get 16-18 MPG. Around town I get 10-12. Mixed I usually get 14. Towing the trailer unloaded I got 12, loaded usually 9-11 depending on the weight. Red has no problems pulling 8000 pounds of trailer and antique Pontiac.
Mine isn't a dog at all. I can easily smoke the tires. While the V-10 or a PSD will out pull my truck, it does the job for me nicely.
Yes it's a dog.
A loyal, steadfast, long-lived, man's-best-friend kind of a dog that will give it's all and keep going until you put 'er down...
Something sounds fishy.
And on top of what others have already said, clean the MAF.
I'm wondering, with the VVT (really, VCT), if it can get stuck and the PCM won't know it's not working right and not like the CEL?
theres probly something wrong with it. when i first bought my truck millage sucked (7 mpg unloaded) and power sucked i kept bringing it back to the dealer and they said there was nothing wrong with it and i cant expect a big truck to get good fuel millage. at 33000 miles the number 8 rod went through the side of the block and the new engine is much better gets 12-13 mpg in the city unloaded and it seems like there is alot more power.
Dang... typically that would've happened to you 3001 miles later
Yeah, I wouldn't call the 5.4L a dog. Mines only the 2V and has plenty of power for me. I do have the 4.10s though and that does help.
My 5.4 is by no means a dog, and given the times I driven V10's unloaded they felt exactly the same.
I do know for a fact they will win a drag race against a ZR1 S10 and blazer... my roomate has one and I love rubbing his nose in it
Check your exhaust for clogs, 9.5 sounds a little low. As previously suggested, a good tune up should do the trick. Cold weather makes these things use a lot more gas though!
