repost Bought a Money Pit
I will stick with the short story Yea Right, Got 1986 E350 460 with Air/Smog & EGR system. Had a broken exhust bolt on left side of head, Going to replace head and reinstall headers and remove stock exhaust and i want to leave off Smog and Air Pump and EGR. My question is on the intake do i install the stock gasket and let the exhaust dead head in to the intake or instll a new intake gasket the blocks the return to the intake.
Any ideals on Stock crab or upgrade it.
Thanks
Eddie
Thanks
Eddie
Eddie,
A lot depends on what you want from the engine, which are you looking at?
Weiand Stealth and Edelbrock Performer's are pretty close to stock, but will probably save you 40 lbs over the cast iron one.
An issue I could see in a van is clearance on top with anything higher.
(don't know...)
There are block off plates, or solid spacers if you want to loose the EGR, but expect some tuning.
7DF250
13
03-20-2011 01:00 AM
1980F15049
11-07-2009 09:48 AM
RancheroMK
06-09-2003 07:24 PM
