What size tubing are my brake lines?
I need to order a roll of metal tubing to fabricate new brake lines for my F350 4x4 dump bed. I measured the OD of the tubing with a caliper and it measures about .21 inches. Is the tubing sold referencing ID or OD? Does any one know a good source that sells it by the roll with the fittings? The Master cylinder has 2 different size fittings, I assume so you hook it up only one way. I'd like to swap out the Mater Cylinder as well, but I read posts here of people having bad luck with Autozone rebuilds. Anyone have a good source for these brake parts?
Thanks fred
Thanks fred
Thanx..They are 3/16ths. I took the flare tool out to them and matched them up. To the guy who told me they were 5/16th's thanx for nothing. If you don't know what yer jawing about don't post.
Could not find my flare tool..Now I found it. It does not have the adapters for the double flare. Thanx for all your useful info as well.
Hey Fred chill out.
Brake tubing numbers signify the outside diameter.
You said you measured the brake line OD and it was .21 inches.
A 3/16 brake line would measure .1875.
What you're sayiing doesn't make any sense.
Most common brake tubing size used in older US vehicles is 3/16 or 1/4.
on
1 Post
ford: 3/16 front and rear with 2 funky fittings: drivers side of the rear axle jblock and front M/C reservoir fitting.
first fitting - childs play at advance et al.
second fitting: generally unobtanium, cut an end, use the old fitting and reflare.
for the record: since ford loves to rustout the frame lines in a spot dujour, dont use a 1 piece line from the ABS to the hose. use 2-3 lines so repairs can happen.
Sorry, I do not recall the part number. I can post a picture of one if anyone would like to see what they look like.
Edit; found picture
3/16" line with a adapter for the "big" end.
