stupid headers
stupid headers
I got the bright idea of installing headers on my 90 F150 302 4x4. Picked up a used set off ebay, sandblasted them and painted them with hi-temp paint. The manifolds unbolted with no probs at all, and the headers bolted right in without a snag.
Naturally, I knew it couldnt be that easy. Both flanges exit too low & just in front of the transmission crossmember, and at a slight angle to make it more fun. I took a piece of 2.5" pipe to the exhaust shop to have them tweak it to my 'exact specifications'...of course, it doesnt fit..no surprise there. So tonight I had to order some mandrel bent pipe to weld up and snake up and around the crossmember.
I have a Summit brand 3" muffler and a flowmaster merge pipe (dual 2.5" inlet to a single 3" outlet) which will fit right up in the event I ever get the piping that far back. I also ordered a tailpipe for a F350 diesel (I think its 3" diameter)
Until then, truck is enjoying an extended vacation in my garage.
I ran into the same problem when I put the Flowtech headers on my truck. I ended up cutting back the collectors a little and used the flex exhaust from Autozone to run under the crossmember. Then I 'modified' the old y-pipe behind the crossmember and clamped it all together for now. Once I get my custom cage built and pull the body and bed off, I'm going to fabricate the exhaust better, but for right now it works.
You can see the pics of mine about halfway done this page I have:
Links and Pics
Links and Pics
This was a new set. Conanski recommended them because his had plenty of room. But his turned out to be older too. Even he just got another set and was disappointed that they were longer than his old ones. I got these about 6 months ago.
on
