replace E4OD
Old Nov 21, 2008 | 05:50 PM
Keanen's Avatar
Keanen
replace E4OD
Is there any transmission that will fit in my 96 F350 4x4 diesel other than the E4OD, I'm not real impressed with it and it's high dollar to rebuild or replace.
Old Nov 21, 2008 | 06:16 PM
andym's Avatar
andym
A C6 will, but it doesn't have overdrive. Your gas mileage will drop considerably. A ZF 5 speed will also work, but you will have to install a hydraulic clutch system and use a different pedal assembly. Either way, you're going to need different length driveshafts.
