Super Duty Theft Attempt Please Help!
Well guys this happened a little while ago, but hopefully someone on here will be able to help me out.
So, I pulled into my friends driveway about 3.30pm right off Chevrolet Ave across from Kettering University (formerly General Motors Institute) in Flint, MI. I had to run in the house to grab a few things, so i shut the truck off and ran inside (took keys with me, did not lock it). Come out of the house after 1 cigarette (so about 5 minutes later) to find my driver side door open, hood open, and truck running happily with no keys in the ignition or visible damage.
Much to my chagrin, I later learned neither of my heated seats work and my remote car starter/ alarm are no longer with the truck. I also don't have a horn. So poking my head under the hood I noticed a few things that don't appear factory stock- and hopefully someone on here will recognize what these wires are for.
the siren/ horn for alarm, please note that the wire spliced into it's hot wire is white with a black stripe... could that have came from the factory harness anywhere?
And these are my cool new exhaust tips lol
Any help would be awesome... its really F*ing cold out there and i miss my heated seats and horn. The remote starter was nice but not necessary like the heated seats. Thanks guys!
The pass through wires come out under the dash. I have a diesel so I dont know if their location is the same or not but mine are near the parking brake. They are simply pass through wires so you dont have to drill holes in the firewall to run wires through.
Have you checked all the fuses? Do any of the non functional items run on the same circuit? i.e. could 1 cut wire be the power feed for the seats and horn?
But yeah, campus security actually whitnessed it happen but they thought it was me because it the guy was same build/ race as me. Ironically when I filed a police report the description matched the same description of a guy that stole an 87 Grand National out of the parking lot across from where I had parked.
But now, I dont have remote start and my butt is really freaking cold in this 26 degree weather.
Anyone got ideas where a remote start/ aftermarket alarm mechanism would be located? I have an LED in the dash but don't want to pull everyhting apart to trace the wire.
Also, I have found a couple holes drilled in the firewall. My guess is the PO either didn't know about the auxilary wires or had them occupied with plow equipment? I did manage to find a random black wire going the length of the truck and ending just short of the passenger side tail light.
So... how do I troubleshoot all these electrical issues?
I just noticed today that I have the same cut wires as in your first two pics, no clue what they're for.
Just what I was thinking. Someone followed you home man, creepy.
But seriously I would blame it no the aftermarket alarm and remote start. I have seen them do CRAZY things to cars just out of the blue.
those wires come from the factory like that. they should match the OBD port wires, the holes in the fire wall are factory to.
[quote=locknload223;6796145]I just noticed today that I have the same cut wires as in your first two pics, no clue what they're for.
That was explained in one of the above posts. They are pass-through wires so you don't have to drill through the firewall if you need to run wires in/out of the cab. I.E., I used those to run the wires from my alarm out to my siren. I also used them to run a power wire out to my battery from in the cab.
As mentioned above the other end of those wires terminate in the cab up above the e-brake pedal. Most of the time they are taped up to an existing loom.
I've tried taking my key out several times to get it to run without the key several times... no luck
