94 300 exhaust manifolds - to gasket or not to gasket
Old 11-21-2008, 09:27 AM
rando76's Avatar
rando76
rando76 is offline
I have a 94 F150 with a 300. I have pulled the manifolds due to cracks and the infamous "clicking". I bought two new manifolds - both front and rear. I'm not sure whether I should use a gasket or not. I know Ford didn't use a gasket, but that doesn't mean it's the right thing to do. With two new manifolds, do you guys think I should put on a gasket or use graphite grease? Advice is greatly appreciated.
Old 11-21-2008, 01:07 PM
Harte3's Avatar
Harte3
Harte3 is offline
The factory has a bit different situation when assembling these things then we have when re-doing them. Don't know about the EFI but gasket sets for the carbed engines are full length and cover the intake and exhaust. The three times I removed manifolds from a carbed application I used a gasket (Fel-Pro) for the install even though the factory did not use them. If the EFI manifolds share mounting bolts/washers I would think that a full gasket set would be necessary.
Spktyr
12-16-2016 10:18 PM
fromme87
10-24-2015 05:21 PM
whale15
1983 - 2012 Ranger & B-Series
05-16-2015 06:22 PM
Old Coyote
07-24-2012 11:05 AM
Ol Rudy
02-10-2004 12:40 AM
Quick Reply: 94 300 exhaust manifolds - to gasket or not to gasket
