Diff Rumble
Old Nov 17, 2008 | 12:06 PM
propaneman's Avatar
propaneman
Diff Rumble
I have a rumble coming from the rear of the vehicle when I turn.
It does it more on left turns than right and you have to be turning on dry roads.
It only does it when torque is being applied (gas petal depressed).
I think my rear diff is the source. If so, what action needs to be taken to fix it? Anyone with a similar issue in the past/present?
Thanks,
Billy
Old Nov 17, 2008 | 12:12 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Which rear end do you have? If you would fill out your sig, we would know more about your truck just by looking at you sig.
Old Nov 17, 2008 | 12:16 PM
triskit16's Avatar
triskit16
Did you change your diff fluid? There is an additive you need to add to it if you have and didnt switch to a good brand that has it added in already. I believe it only applies to limited slip rears so let us know which you have.
