Go Back   Ford Truck Enthusiasts Forums > Diesel > 4.4L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
4.4L Ford Diesel Discuss the much rumored 4.4L Ford diesel engine
Is F-150 Still King?
  #16 (permalink)
Old 11-20-2008, 02:01 PM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Red2003XLT View Post
In past years the F-150 was the best selling vehicle due to fleet sales.
If GM goes through with a diesel for their 1/2 tons, Ford can kiss that best selling label goodbye, permanently
GM had 1/2 ton diesels from around 1978 till at least into the 90s. It was in an era with diesel fuel cheaper than gas, no DPFs and no urea tanks. I don't seem to remember Ford sales suffering too much as a result then.
__________________
2004 E-450 6.0 137,500 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #17 (permalink)
Old 11-20-2008, 04:31 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Y did they stop? Diesel fuel was the cheapest fuel up until the fall of 05(ironically when I took position of my current money pit of a truck(I mean that in a good way as I to love this truck)).
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #18 (permalink)
Old 11-20-2008, 06:01 PM
One factor may have been increasing difficulty meeting the 1/2 ton emission standards with the fuels available in that time period.
__________________
one EGR valve.
  #19 (permalink)
Old 11-23-2008, 06:26 PM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
Chevys diesel back then was a diesel that Nobody really wanted. Probably a good reason to discontinue it. no power, unresponsive, loud clatter and not real reliable.
The new "Mini-Max should prove to be a very sought after engine. I for one will buy the first Suburban/Expedition i see with an oil burner under the hood.
I am not brand loyal. I believe that all three of the "Big Three" make a good truck. Each of them have bragging points and each has something not so great. Chevy has the Allison, Ford has the truck its self and Dodge has the Cummins.
I need to replace the Excursion that I wrecked and I really don't need anything that heavy duty. Just want an SUV that will get fair MPG while towing the toys. For me, that spells diesel.
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
  #20 (permalink)
Old 11-23-2008, 08:31 PM
smokin_h's Avatar
smokin_h smokin_h is offline
smokin_h is starting off with a positive reputation.
Dang I oughta scrap my engine and trans and just put a cummins engine strapped to an allison trans and I would have the most bad a$$ truck around!!!
  #21 (permalink)
Old 11-26-2008, 11:31 PM
Ed_B Ed_B is offline
Ed_B is starting off with a positive reputation.
I've been a Ford man for a long time now. It's not that I am a dedicated fan of Fords either. Ford has to EARN my business and up until now they have done just that.
I have an '84 F250 4x4 with the NP435 trans, NP208 xfer case, and 300 CID 6-cylinder engine. My plan was to buy a 2010 F150 diesel truck and sell the F250 to anyone who wants a tough old truck for hunting, fishing, or just plain off-road thrashin' and bashin'. If Ford cancels or delays the diesel F150, I will have to buy something else in 2010. I don't like the idea of buying a foreign made truck but will do so if they offer a product that works for me.
Like I said above... Ford has to EARN my business. I'm not going to hand it to them on a plate just because they are my preferred auto builder.
Ed
  #22 (permalink)
Old 11-27-2008, 12:00 AM
mnmwhit's Avatar
Quote:
Now that would be a truck I would buy
__________________
Wabasto-Blue heat
  #23 (permalink)
Old 12-11-2008, 12:39 AM
bdraft bdraft is offline
bdraft is starting off with a positive reputation.
You're not the first that have mentioned that I think.
I've seen several Ford/Cummings Frankenstein'es in magazines, I don't remember what tranny any of them were running, except that I think one was running a manual tranny....
just a thought;
bdraft
  #24 (permalink)
Old 12-14-2008, 04:27 AM
orng1's Avatar
orng1 orng1 is online now
orng1 has a good reputation on FTE. orng1 has a good reputation on FTE.
That would be an awesome truck that would own the entire truck market. Why not get together so they can get out of debt?
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #25 (permalink)
Old 12-14-2008, 05:28 AM
Quote:
Short answer:
In a nutshell....too much bitchin' not enough buildin'.
Long Answer:
Because they would spend too much time fighting on the name of the rig or selling it badged in their own name, the companies couldn't agree on what we know so each would expect to build the whole truck and sell it to the other companies, the committees that would go along with it would be a killer....
Then again, there are other good diesel engine companies out there. CAT supposedly makes several decent engines that would fit into various trucks (and cars), just like Cummings does.
Then again, some of the larger trucks have 'manu-matics' (auto-shifting manuals) and clutchless manuals that might serve better than an automatic. (That is one thing I hate about Ford, they car cutting back on the vehicle and engine combination that are available with manuals....seems to me if Ford could go with a 100% automatic fleet they'd be happier.)
thank you for your time;
bdraft
  #26 (permalink)
Old 12-14-2008, 06:56 PM
Quote:
Yeah, they probably would... right up to the point where their customers would leave them in droves. Slush box? BAH!
Ed
  #27 (permalink)
Old 12-14-2008, 11:53 PM
dspencer dspencer is offline
dspencer is starting off with a positive reputation.
The early Chevy diesels were rebuilt gas engines and they stunk for reliability. My brother in law had one working the oil fields that constantly was having fuel delivery problems.
Its a wonder that the next generation of diesels didn't get waylayed by those first pieces of stuff.
I don't blame any of the manufacturers for not bringing the half tons to market at this time. If you've noticed the price of diesel which was about 15 percent higher than gas about a year ago is now 60 percent higher. They would have to make a diesel that gets in excess of 30 mpg to be an advantage over a gasser. With the higher cost of a diesel they would be a hard sell and something they don't need right now.
__________________
2000 Dodge 2500 QC 3.55 5sp DonM1.6 injectors EZ
2003 Jetta tdi 5sp. upper 40's overall mpg.
  #28 (permalink)
Old 12-15-2008, 07:08 AM
Quote:
I agree with you on the higher cost of diesel, but a Dodge Ram 2500 with a Cummings 12 valve has pulled off 30.1 mpg when a magazine tried some cheap tricks to get better mileage. (None of it was computer work, the 12v didn't have computers for the most part.)
Now with that in mind; a lighter weight half-ton truck with user selectable power/tow/economy switch and programing in the computer to adjust....why wouldn't it be possible to get outstanding mileage?? You could even have the computer select 'economy mode' when certain conditions are met....why couldn't a truck get 30, maybe 35mpg even if the driver had the A/C on full blast?? That is coming close to double the best that the current crop of gassers can manage.
later;
bdraft
  #29 (permalink)
Old 12-15-2008, 09:51 AM
tex25025's Avatar
They were pieces of crap, however, all manufactors did that at one time or another. But due to Chevies worse luck then the others, I would neve get a duramax.
Maybe, but that all depends. Certainly if it's just a daily driver, then what you say might have a lot of weight. However, if they use it for other things then just a daily driver, then you have to factors those in, not just mpgs. All this is dependant on the specs of the truck though as well.
__________________
Fluidampner
Headstuds
FASS 150/180
  #30 (permalink)
Old 12-15-2008, 06:34 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Quote:
Originally Posted by tex25025 View Post
Y did they stop? Diesel fuel was the cheapest fuel up until the fall of 05....
Can you spell I-R-A-Q?
At the peak of the war effort and recovery efforts, the US military and construction contractors were consuming 1,000,000 gallons of diesel per DAY. Couple that with the fact that the refineries in this country are oriented towards higher efficiencies in gasoline production, and not diesel production, and the net result is a big drain on the supply chain for diesel fuel and correspondingly higher prices.
If the promised petro expansions along the gulf coast result in processes oriented more towards diesel production, the gasoline:diesel production ratios may become more balanced and we could see a closer alignment of prices between the two again. But the consumption overseas from military action would need to be curtailed for the real price cut that we all want.
To go along with that, though, the automakers are going to have to be directing this shift in petroleum refining efficiency. Until the production and operation of more diesel engines takes place over here (like it is in Europe), the gasoline engine will drive refinery operations in that direction and leave those of us wanting diesel having to pay higher prices.
Don't get me wrong here, I do not want to, and am not trying to fuel a discussion on military action overseas! NADA! Just talking about the effects of supply & demand.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
Tags
12 , 2010 , brand , delay , diesel , diesels , f250 , ford , forum , half , ranger , ton , truck , trucks , wrangler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
