I believe that the picture problem is a server issue Joe. I have 3 different browsers that I run on my PC. I can open the same post in any of the browsers and get the same result. Even if I do an "open image in new tab" I get the red x. Doesn't seem to matter where the image is hosted at either, although I have not had the problem using my picasa account. I can usually dissect the code and make it work, but something has changed.
It has definitely changed on the Internet Brands side of things (i.e. FTE)...I've posted pictures the same way for nearly 7 years...and now there's an issue...
Just a few weeks ago FTE was running very slow and causing pages of threads to "drop out" and when you were posting you got an error...so FTE was doing some pretty extensive changes "behind the scenes"...I suspect this is one fall out they haven't cleaned up yet...I'm confident they'll get it figured out though!
Well Joe, I tried all the tricks that I could. The only way to do it using webshots is to take the http off the link to make it not recognize the url. That will give others a link to open.
