Headliner question - 73 F250
Hi. The old headliner in my truck was brittle and completely fell apart. Time to replace it. I see that people use Kilmat under the new headliner for soundproofing. That stuff seems pretty thin compared to the foam that was under mine. Is there some foam or padding or something that should be put under the Kilmat? Or not necessary to do that? Any links to other discussions about replacing headliners also greatly appreciated. Thanks.
Check out this thread. https://www.ford-trucks.com/forums/1...eadliner+cheap
Self adhesive "boom mat", Dyna Mat, or other sound deadener is nice to put on the underside of the roof.
Did you have foam or a blended material (Shoddy Pad) like the stuff behind the door panels?
https://www.detroitmuscletechnologie...xoCe1UQAvD_BwE
The following users liked this post:
Hey, while I'm thinking on it .... do you ever recall if hearing about that stuff holding condensed moisture near metal, or if it shields against it? I think it would shield from condensation? I haven't any rust, it's all sound ... but it has some surface patina. I usually used windows down even when AC was working.
So put "boom mat" or Dyna Mat or shoddy pad under the kilmat?
73f250BBetty
01-02-2023 06:03 PM
Quantum77
11-06-2010 10:51 PM
