Tokico composite overload springs? and others Qs
Has anyone tried these?
<http://www.tokicogasshocks.com/truck/loadleaf.html>
I need to redo my rear suspension as the ride is killing me! I've got the stock spring pack with the Rancho add-a-leaf lift. Brutal ride until I put at least 350 pounds of cargo in the bed, and that's with the weight of a SnugTop!
I'm thinking of taking out the add-a-leaf , and switching to a block lift, the Tokico overload springs and possibly BFG Velvet-ride shackles.
I'm not worried about spring wrap with the lift blocks as I have traction bars. I don't know if the BFG Velvet-ride shackles will even do anything with the added weight of the SnugTop possibly bottoming out the rubber in the shackles.
Has any used any of the teflon/slick plastic inserts that go between each spring to reduce the friction in the pack?
85 F150 4x4, Bal & BP 302, EFI, K&N air filter, Heddman headers, High-flow Cats, Custom side-exit exhaust, 4" Rancho lift, Rancho 9000 shocks, Rancho Torque Arms, 4.10:1 gears, Rear limited slip diff., 33" BFGs, Warn Winch, SnugTop.
1995F150XLT4x4
Ford Truck Parts for Sale
08-24-2015 05:03 PM
sandman3510
12-03-2003 08:23 PM
