Sound proofed the truck
You don't even need a trim tool for these panels. A small, flat blade screw driver will pop off any of the covers you need to remove to get to the screws, at least with power windows. I guess I've never taken a panel off one of these trucks with manual windows, so that may be a bit different.
on
on
I purchased mine from:
Drivetrain and Underhood Accessories-Dodge Cummins and Ford Power Stroke Diesel Truck Accessories - Geno's Garage
I've known the folks at Geno's Garage for years. Very easy to deal with, best return policies. Insulates head/cold as well as sound. I've used it under the driver's carpet on my Super Duty and will soon be adding it to the back of the cab under the carpet on my F150.
I wonder if this stuff is the same but non-self-adhesive stuff they use for wrapping heating ducts. Our local hardware chain store sells it by the foot wide roll for somewhat cheap.
I assume the adhesive is permanent, so it'll be a fuzzy mess if you change your mind later.
I'm tempted to try some aluminized water heater jacket material to achieve the same. A sheet big enough to wrap a 60gal water heater goes for $20
It's about 1/2" thick and fairly dense. That's more than enough to cover the back wall.
The heating duct tape is not as "sound absorbent". I used it first and found that it needs to be doubled or tripled to be effective.
I ended up soundproofing my Excursion with B-Quiet. Not as expensive as Dynamat but very effective! I've yet to do the roof but hear that it makes a big difference. However, the doors and the floor pan up front was the biggest change for me.
