Turn off TPMS?
Turn off TPMS?
2008 F-350 Lariat, 6.4L, 4X4, crew cab, short box, 3.55 rear end, factory 18" wheels, no mods
This is the only thing I don't like about the truck. I have to run 63 psi all the way around to keep the icon light and info center warning off. My back tires are not even flat on the ground at this pressure! Dealer says they cannot recalibrate it to allow a lower pressure. Is there a trick to getting into the computer menu or something to adjust it or turn it off, like people do with the door chime, maybe?
No, there is no simple trick. It takes manual configuration of the programming in both the GEM/SJB and ICM to turn it off. Only the ICM needs to be reconfigured to readjust the pressure set points. You need a Ford computer to do it and if one thing is done wrong, you endup with a dead truck. As you have already found out, dealers are not allowed (nor taught) to do this due to Federal regulations...
TPMS is a federally mandated system like seat belts and smog controls. The fines are extreme should they change things. If you are really serious about making a change you can purchase your own programming tool; TPMS Tools - Tire Pressure Monitoring Systems
IDS Home
Even with the correct equipment, there is no simple TPMS menu option for on/of or pressure set point adjusment. You actually have to know what individual parameters need to be changed and where...
dioxippus
35
07-24-2022 09:19 AM
TDean
11-08-2008 10:30 PM
