2000 Excursion V10 exhaust manifold
More then likely the bolt heads broke off, quite common on these trucks. Hopefully they can get the broken off bolts out easily enough.
I know some V8's had issues with cracking manifolds (expeditions I think?) but have yet to hear of it on a V10 personally. Go see if all the bolt heads are visible on your manifolds.
Exhaust Studs Broke Off
I just went out and did a quick check and I found 2 on the rt. side broke off.
Havent gone under to see if there are others. Do any of You folks know what it cost on average to remove one at a shop or dealer. The 2 I found are right in the area of the rt. frt. shock. What was there problem with the studs they used? Is there any call back on them? Please Help.
Thanks
Jim
Thanks
Jim
lexcoe
23
01-23-2012 09:52 AM
