Best place to mount front tow hooks?
well if you look under the front end behind the bumper right off the frame theres a bracket (basically a big piece of angle iron) thats welded right to outside of the frame i use that and it holds well and i wouldnt be worried by drilling/welding on it and theres one on both sides so you can put it where you want it
on
1 Post
seriously.
The chevy front end frame (S/T/C/K/E/V models) is reinforced (twice as thick, boxed, 2 times as thick front cross member) to support this operation.
the ford frame is notoriously weak in front of the engine cross member and any forces placed on it WILL bend the frame.
I did not say MIGHT
I did not say COULD
I said WILL.
Partially good news is that you can bend it back with a CWOUS (crescent wrench of unusual size)
Does not matter what size F series truck this is - all weak weak weak
But if you are gonna do it anyways, find an old scrapped plow for a ford and cut off the frame mount and weld it to your truck. then at least you can say you made the effort.
On a chevy....
seriously.
I did not say MIGHT
I did not say COULD
I said WILL.
seriously.
I did not say MIGHT
I did not say COULD
I said WILL.
On a chevy....
seriously.
I did not say MIGHT
I did not say COULD
I said WILL.
seriously.
I did not say MIGHT
I did not say COULD
I said WILL.
Fords have the big heavy rear bumpers and chevy's have the reinforced front frames. Guess chevy knew the destiny......
on
1 Post
but by any means, never take my word for it. just climb underneath a few trucks and check it out for yourselves.
chevy doesnt and it says right in the manual that they do not recomend their trucks for plowing purposes, wonder why that is, cause of their weak front ends, a arms suck, at least ford puts a real axle under their old F.series, a arms are good on 4 wheelers and cars, but thats bout it, btw i had a 91 f.150 with a home made winch bumper and a warn 12,000 lb winch, ive parked sideways on the road and pulled people out of ditches which are at a lower point than my truck and my receiver in the back chained to a tree and my frame was as straight the day i sold it as it was when it rolled off the assembly line, if ford figured these trucks would get stuck they would have put factory tow hooks on them btw pi$$ on chevy
