Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-20-2008, 08:57 PM
Kongslibakken's Avatar
Kongslibakken Kongslibakken is offline
Kongslibakken is starting off with a positive reputation.
Swapped 4.0's Computer Reprogram?
Hey Guys I recently switched motors in a 96 Explorer Sport I went from Hydrolocked 1/96 OBDII Motor to a 6/96 OBDII Motor from a rolled Explorer. I fired it up now I have a High Idle 2500 rpm's it runs smooth but when it comes down to 1000 rpms it runs rough. It starts hard after it warms up. Do I need to do anything to reprogram the computer or have I lost a sensor. The code reader shows no codes. Any ideas are welcome. Thanks
__________________
When I figure out what I'm doing I'll let you know.
  #2 (permalink)
Old 10-21-2008, 10:48 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
There should be virtually no difference between those two motors. I would check for vacuum leaks, and check and clean the IAC and its passages (I assume that the new motor came with its own IAC and that's the one you're using?) and it wouldn't hurt to clean the MAF and Throttle Body as well. Be sure to use a spray cleaner designed for cleaning throttle bodies, not just plain old carb & choker cleaner though.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 10-22-2008, 07:37 PM
Thanks I'll give it a try each little step is making things better. Are you in the true part of NorCal??
__________________
  #4 (permalink)
Old 10-23-2008, 01:04 AM
TigerDan's Avatar
1968 Ford F-250
I guess that would depend on what you consider the "true part"... I'm about 2 hours north of the San Francisco Bay Area. Jeg betenke det ĺ bli avrette nord...
__________________
FTE Moderator
  #5 (permalink)
Old 10-24-2008, 01:47 PM
Ikke bry deg som er langt nok nord jeg bodde i Redding og Yreka. I didn't think there were to many of us up there. You should know what Kongslibakken Means
__________________
  #6 (permalink)
Old 10-24-2008, 08:35 PM
TigerDan's Avatar
1968 Ford F-250
I used to live in French Gulch, just outside Redding, but I'm a bit further south now. And I don't actually do too well in Norwegian, I lived in Sweden for a year so I'm a bit more fluent in Svenska. But they're pretty close...
__________________
FTE Moderator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
