Stage 1's are in with no change
Well, I got the injectors rebuilt and installed. Now that this is done it takes longer for the truck to start. There is no difference than before. If I'm on a flat road,with my superchips on high perf I can get up to 70mph. There are lots of hills around here and any slight incline she's all done. If I put it to the floor while going up hill it will down shift and hover at about 2300rpm then the rpms will drop. Feels like it is defueling or something. I think I'm gonna have to take it to a local diesel shop and have them scan it. Which way is the ebpv in the open position? I want to make sure it is actually open and I really don't want to remove the dp to check it. Any other thoughts? Thanks
your superchips is the problem, i bet if you got rid of it and got some custom tuning from tony wildman or jody from dptuner you'd be fine... stage 1s will not gain ANY performance increase from a generic tuner because they have the same size nozzles as a stock injector and therefore will not flow any extra fuel without custom tuning
sorry i haven't been on this site a lot lately, i just read over what's been happening with your truck and at the time i would've agreed with what everyone else said about injector o-rings... are you sure all the injectors seated? i'm not sure what would happen if one didn't but i'm assuming it would have some leaks that would be kind of like an injector o-ring leak... do you have any way to check ICP and IPR #s to check the HPOP?
you can check the HPOP resevoir by using an allen key to open the top, the resevoir is in front and above the HPOP, it looks like basically a big metal container kinda... hard to explain.. but it does not look like it would hold oil... you should be able to shine a light in there and see it, the oil should be right at the top... and if you have a scanner that can read ICP and IPR functions then you can see the psi that the HPOP is running.. mine runs 700-800 at idle in all my tunes and gets over 3000 when i'm WOT and levels out at about 3000 while WOT for a couple seconds... this is with a 17* HPOP from the newer 7.3s... if yours levels out anywhere below 2300 i'd say that could definitely be your problem
optracer100,
How many miles on your rig? Stage 1's will only behave as stock until you change the program files that "drive" the injectors. When I had a superchips "custom programed" flip chip (by them) it was ok....when I switched to Tony Wildman programs there was a HUGE.....change like a different truck....
Your HPOP may not be getting enough oil to the new injectors....you can make up a simple pressure tester by getting some hydraulic hose (high pressure) and a gauge that reads to 4000 psi. Then plumb it into the head and go for a drive, this will give you an overall impression of how the high pressure oil system is running. If you want to test the HPOP then plumb directly to the pump and plug the other outlet.
It will hard start until all the air is out of the system....once out if it hard starts when it is at operating temp then I would look at your IPR and get a rebuild kit for it.
As a first step should get any codes read and deleted out of your PCM, is your superchips a chip or programer?
keeps us informed.
jrc
keeps us informed.
jrc
Jcart, it's a programmer.I'm not worried about getting all the power out of the injectors right now. The truck ran like crap before I changed the inj. I ran it with out the programmer hooked up, so it runs like chit with it hooked up or not. I need to get it sorted out before I worry about getting the most out of my injectors. I'm gonna have to take it somewhere to get it scanned as I don't have access to a scanner myself. There is a diesel shop not too far from here. I may take it there and see what they say.
Glasseater, all the injectors seemed to seat right. I hit them with a mallet until they bottomed out. I can't get the allen bolt out of the hpop. I'm gonna have to give it some more effort.
White smoke??? Are you sure you typed that right? If your seeing WHITE smoke, you have problems. If your getting plenty of fuel, it will be black, as I am hoping that you meant to say.
