newbie looking to buy... fuel mileage question
I have a choice between a 1983, and a 1995, both are in good shape, both are i-6 with standard trans, one is a 4speed auto overdrive, the 95 is a 5 speed , where first acts like a granny. one is carbuerated, the other fuel injected. yet on the govt sites, it rates the 83 at 18 to 22 mpg, and the 95 at 16 to 20. How is this possible? I thought fuel injected was allways better than carb? Also, one is more computer friendly, with newer stuff, so again, with all mechanicals, working, and in good shape, which would you get?
thanks
thanks
I would also buy the 1995. The mileage is going to depend on what gearing the trucks have what condition the motors are in. The 95 will probably get better mileage no matter what the site says. Which one has more miles than the other? The 95 isn't nearly as old as the 83, so it will probably treat you a little better in the repair department. Either way you go, you are getting a very reliable and tough Ford truck, so there really isn't a bad decision.
on
1 Post
Well said depends what the truck is used for if its a daily driver you might want the EFI for more reliability
I had an 83 shorty with the 302 and AOD. Great truck, but had to keep an eye on the carb and electronic ignition module. Lasted 220k and was 21 years old.
Since then. I've had a 94 F150 reg cab shorty 300 5 spd 3.55 gears and a 95 sc with the 300 5spd 3.08 gears. Both of these trucks were much easier to live with than the 83.
BTW the 3.55s made my 94 feel like 1st was a "mini" granny gear. The 3.08s make for nice highway cruising but reverse is a bit tall. If I have to regear I'll look for something in between.
My vote is for the 95 unless the 83 is in excellent condition.
regards
rikard
regards
rikard
