long travle 4x4 kits
I just got a 06 4dr f-150 and i have my old 2003 single cab short bed 4x4 with the 5.4liter sitting there so i was thinking about putting a long travel kit on it and beat on it. it has some performance mods on it already bbk throttle body, bbk headers, flow master exhaust, edge programmer, k and n filter, nice bbk liter pulleys kit with a bigger radiator and transmission cooler. so i came a cross this company called H&M motor sports and i was thinking about getting there front end long travle kit. Heres the link for those of you that want to look at it 1997 to 2003 F150/Expedition 4WD suspension kits i was woundering if anyone had the 4x4 kit and how it proformes? of couse im going to get the rear end done after i get my front end figuared out and a cab cage.
Thanks
Mike
Thanks
Mike
The link doesnt work, so I cant comment on their long travel kit.
If someone did make a long travel kit for the 4wd 97-03 f-150, I bet you would have to swap over to a different kind of spring. I doubt they could make a torsion bar that could flex and twist alot over a long period of time. So the kit would be real expensive and hard to install.
Oh i will re post the link then but yeah its going to be like 7k installed with triple bypass and king coil overs with 16in travel i was hopping someone had the kit out there and tell me if its any good i don't want to drop 7k on a kit then it ends up being a pos. O wow i just tried looking it up on line and the link doesn't work now ma by they are redoing the site or went out of business... if the link starts working again i will re post it
Thanks
mike
Thanks
mike
Ok the site is back up again so here the link for those of you that wanted it 1997 to 2003 F150/Expedition 4WD suspension kits
Thanks
Mike
Thanks
Mike
