What carb will my f350 have.Gas conversion
Old 10-16-2008, 01:46 PM
fordf350camper's Avatar
fordf350camper
fordf350camper is offline
Hi can you help again.I would like to Know what model,make of carb my ford f350 straight 6 223 engine has fitted.Any photos what should be fitted would be great and very helpfull. So i can check with mine to see if its the same as what i have fitted.The reason is i am still thinking of fitting a gas conversion.I have been told i need to know what carb my truck has fitted so i can find the correct modern parts i need to fit the carb.If anyone knows what carb bits i will need woould be a great help.Thanks again
Old 10-16-2008, 01:52 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by fordf350camper
Hi can you help again. I would like to Know what model, make of carb my ford f350 straight 6 223 engine has fitted.
The reason is i am still thinking of fitting a gas conversion. I have been told i need to know what carb my truck has fitted so i can find the correct modern parts i need to fit the carb.
If anyone knows what carb bits i will need woould be a great help. Thanks again
You can buy a CD version of the 1948/56 Ford Truck Parts Catalog from hipoparts.com / Also sold on ebay for a buy it now price.
All the parts are illustrated, so you can also use the catalog for an assembly/dis-assembly manual.
Plus you get all the part numbers.
Considering that the pound Sterling is worth almost twice what the US dollar is the cost to you will be less than 11 pounds.
Old 10-16-2008, 02:09 PM
fordf350camper
Thanks would you know the ebay item number please.Thanks Pete
Old 10-16-2008, 03:49 PM
NumberDummy
Nope, sorry I don't.
Try typing Ford parts manual or Ford parts catalog into the search feature.
Old 10-16-2008, 04:00 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
If it was me I'd first look at the Old Car Manual site and pull the Holley 1904 diagram that's on there. I used the IH one to redo my carb. Same carb, worked great. Stu
Home Page - The Old Car Manual Project
