Offroad & 4x4
Hard Core Wheeling Preperation
Old 10-13-2008, 10:46 PM
Prozon's Avatar
Prozon
Prozon is offline
Well I just admitted defeat today and hauled the truck into a shop to figure out why the beast isn't starting.
I've started throwing things around in my shop getting ready for its arrival. I would like to know what everyone suggests for a truck for some HARD CORE wheeling.
I am putting a snorkle and smoke stacks on, because I messed up my old engine going into mud water about headlight deep. Smoke stacks are not only for looks but hopefully will keep the water out of the exhaust.
I already have these, they just arn't on, because well it doesn't run right now.
What more will I need besides:
37" Super Swamper TSL's
Snorkle
Smoke Stacks
Warn Winch
1 Ton Axles
FOR SOME HARD CORE WHEELIN!!!!!!!
Let me know your opinions, i'd prefer all truck mods not what to bring. Because I am well aware of what I should bring for self recovery and I really don't want another chain arguement.
Trucks mods, if i've left anything out. Let me know what you think!
Old 10-13-2008, 11:14 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
LOCKERS! apparently haha...
Old 10-13-2008, 11:20 PM
Prozon's Avatar
Prozon
Prozon is offline
Surprisingly I never even THOUGHT of lockers.
Now ontop of my first question who knows of the cheapest mother f$@%ing selectable lockers out there? :P
Old 10-13-2008, 11:23 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
good question...i heard somethin bout aussie lockers i think they said round 300 dont know if they are selectable though other than that as far as the ones ive looked at selectables go from 450-800 ahha
Old 10-13-2008, 11:24 PM
Prozon's Avatar
Prozon
Prozon is offline
Okay lemme restate.
THE CHEAPEST LOCKERS.
Haha. I'd weld it but i'm probably not good enough of a welder to do that.
Old 10-13-2008, 11:25 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
aussies are the cheapest (so ive found)
Old 10-13-2008, 11:28 PM
Prozon's Avatar
Prozon
Prozon is offline
Why must lockers be so expensive. -_-
Anyone have any other suggestions?
Old 10-13-2008, 11:29 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
thats what i said
Old 10-13-2008, 11:40 PM
straightsix4x4's Avatar
straightsix4x4
straightsix4x4 is offline
You have stock 4.10s? if not then gears. I'm not sure I would run aussies with 37's See what other people think.
Old 10-13-2008, 11:44 PM
Prozon's Avatar
Prozon
Prozon is offline
Yep. Stock 4.10's.
Old 10-14-2008, 12:46 AM
75F350's Avatar
75F350
75F350 is offline
Define Hardcore. This is different to everyone.
This rig gonna see rocks? Sand? Mud?
Since you are running stacks and some snorkel thing, I can assume deep water.
Diffs and t-case vents will have to be raised. You wil also have to figure out how to keep the water out of the transmission.
I am in water crossings every weekend, and I tear my axles apart every third trip. Water is inside every time. I replace bearings more often than I buy shoes.
Maintenance is critical for vehicles that see this much water.
Old 10-14-2008, 07:36 AM
Truckin4life's Avatar
Truckin4life
Truckin4life is offline
Street Queen to the extr3m3
Well im glad i see winch on there....
GOOD recovery points, best if there welded to the frame.
You COULD use more gears but i think you will be OK for now. But if your goin to get lockers do gears also.
Welding isnt that hard, probably have some one do it for you for a hundred bucks or less really.
Roll bar? or cage? Got one?
Safety Restraints. Make sure its got factory seat belts at the least.
I fully agree with 75f350.
Preventive maintenance if crucial with mud and water.
Any time you get back from a day in the mud toss one of those water sprinklers that waves back and forth.... Put one under the truck, then after a few hours pull it out and move the truck, after it dries up some, grease everything. I just replaced all the ujoint on both shafts of my truck, i did them all with the greaseable u-joints, for that extra security.
In mud and water, keep things lubed is very important, along with changing fluids frequently.
Ill post up when i think of some other things.
Also see what the prices of spools and mini spools are running.
Old 10-14-2008, 11:21 AM
straightsix4x4
with the 460 4.10s will be fine with 37's, Especially for mud, lots of wheel speed can be made from that combo.
Old 10-14-2008, 11:33 AM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
i thought it was a bad thing to weld directly to a frame?
Old 10-14-2008, 11:58 AM
Truckin4life
why do you think that????
Quick Reply: Hard Core Wheeling Preperation
