In tank fuel pump cross year fit
I ran into this site that shows a tank replacement and they also show the fuel pump in the 92 ford. My question is was this a high pressure replacement for low in the tank and high on the rail or did they start doing 4.6l by this year and it used different fuel line psi? And do the cross fit question, could a high pressure tank pump be used in an older 5.0 EFI if the high off the rail was bypassed?
Thanks!
site link
http://www.fourwheeler.com/projectbu.../photo_06.html
Thanks!
site link
No, Ford started using the high pressure in-tank pumps in 1990. Prior to that the high pressure pump was external. The line pressure is the same.
I believe the tank openings are different sizes for the hi/low pumps. So if you wanted to convert for some reason you might need to swap tanks as well. Not 100% sure on this, though.
That's what I was after Andym. My truck is a 86 with low in the tank, high on the rail. I just replaced the pump/sender with the fancy brass float in the back tank but in my searches for the vent hose line(mine was dry rotted and not connected) found that link and wondered if single high pres in the tank conversion was probable/possible.
I'm guessing 90+ high pressure tank pumps have done something different with the sending unit?
I just found out that Ford had a change with the in tank fuel pump in 93?
I was told by the local stealership that there is a jumper wire I was going to have to buy to put a new pump in. I'm starting to wonder if I am going to have to put it in the shop to change the fuel pump
The fuel pumps are all the same from 1990-1996 for the same size tank and position tank (front/rear).
There is not any wiring differences from 1990-1996 for F-series trucks.
It was the price he quoted me with some kind of jumper wire $280.00 and I went to FTE Parts guy he was a 100 cheaper. O'Reillys Auto Parts is the cheapest so far.
For some reason I had it in my head that the fuel pump went in the same way that my 85 F150 EFI did
original pump F3TZ9A407C r/b F6TZ9A407CA and loom F8PZ9A213AA REPLACED BY
F6TZ9A407CC AND F8PZ9A213AB you need the wire connector(loom) to connect to the style pump.
WIRING ASY., FUEL SENDER [GAS, CONVERTS ORIGINAL WIRING
FOR 4 WAY MICRO-PPIN CNNECTOR THAT ATTACHES TO THE MAIN
BODY WIRING HARNESS 14405 AT CHASSIS CROSSMEMBER.
REQUIRED TO USE 1996 9A407 FOR 1990-95 VEHICLES..]
The O'Reillys part might just be a pump and not the assy like the OEM replacement.
Ed
Ed
Ed
Ed
