Modifying a 460 Edlebrock Air Gap
Old 10-11-2008, 03:33 PM
F350 Strait's Avatar
F350 Strait
F350 Strait is offline
I'm running a 545 with an Edlebrock dual-plane Air Gap. I've been thinking of grinding most of the wall between the two plenums - at least to the floor of the upper plenum for a little more performance. At this time I don't want to go to a single-plane manifold. I have this engine in a '79 F350 that I pull a fifth wheel trailer and I feel that the dual-plane gives me a little more lower end torque and I'm not looking for power up high.
Can anyone tell me if this will work?
Thanks
Old 10-22-2008, 02:24 PM
ReAX's Avatar
ReAX
ReAX is offline
It's aluminum and if you do go too far you can patch it pretty easily. However it would probably be much easier to put in a spacer to increase the phenolic volume.
Old 10-22-2008, 08:31 PM
F350 Strait
Thanks ReAX
I have a spacer and found out at the machine shop that I use that I can notch & blend the parts of the spacer that separates the 4 carb openings - it's not an open plenum spacer. It should be easier than cutting on the intake.
BigBlocker0248
06-28-2015 05:47 PM
Huntersbo
03-05-2011 05:04 PM
F350 Strait
05-17-2010 01:21 PM
rockher_man
10-11-2009 11:44 AM
Rubiranch
23
12-04-2005 02:02 PM
Quick Reply: Modifying a 460 Edlebrock Air Gap
