How to Change Rear End Oil?
Old 09-29-2008, 11:37 AM
URX111's Avatar
URX111
URX111 is offline
Is there a easy way to change my rear end oil? I have a 1989 Ranger. What is EOAZ-19580-A That is the oil my book says to use.
Old 09-29-2008, 12:58 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
The Ford spec is ESP-M2C154-A which is GL-5 80W90.
I use Amsoil 80W90 synthetic in my 87. Seems to work quite good as I have 240,000 on the truck & never had a problem with the differential.
I use the same oil in the manual trans & no problems with the trans either.
It's been a loooong time since I swapeed diff fluid & I cant remember if the diff has a drain plug or if I siphoned the old stuff out thru the fill hole.
Old 09-29-2008, 02:32 PM
michigan66's Avatar
michigan66
michigan66 is offline
Another approach is to remove the bolts that hold the differential cover in place, remove the cover, and let the lube drain. I'd encourage you to get a new gasket before doing this. Also, I'd recommend a synthetic fluid. Good luck.
Old 09-29-2008, 04:10 PM
BuffmanLT1's Avatar
BuffmanLT1
BuffmanLT1 is offline
if you have a clutch style limited slip differential (like a stock LSD) i'd highly recommend a conventional oil, to ensure continued operation of that LSD.
Old 09-29-2008, 04:38 PM
Dan Robertson's Avatar
Dan Robertson
Dan Robertson is offline
I have a 98 Ranger and have changed the differential oil twice. I remove the pan and let it drain. My truck calls for 80-90 in the differential and ATF in the manual transmission. I use silicone type sealer rather than a gasket. (I'm not sure if they even have a gasket anymore)
Old 09-29-2008, 06:17 PM
Peter94's Avatar
Peter94
Peter94 is offline
Last time I checked my parts store didnt even stock a gasket for an 8.8/7.5. I think standard procedure is to just use RTV, let it cure for 10 min on the pan, and then stick it on.
If you have a limited slip diff, make sure you use the friction modifier with your gear oil.
Old 09-29-2008, 08:09 PM
URX111's Avatar
URX111
URX111 is offline
Thanks for your replys
I don't know if I have limited slip differencle. I'll try to get a gasket and look. Is there another way to tell if it's a LSD?
TNX
Old 09-29-2008, 09:52 PM
reddog99's Avatar
reddog99
reddog99 is offline
TNX
Jack up the rear end with both wheels off the ground, the tranny in neutral, & the E-brake released. Rotate one rear wheel (by hand) and watch the other wheel. If the other wheel turns in the same direction as the one you're turning, the diff is a LSD. If the other wheel turns in the opposite direction, you have an "open" diff. (non-LSD).
Old 09-30-2008, 09:09 AM
nd925's Avatar
nd925
nd925 is offline
Chock those front wheels so the truck doesn't move.
Old 10-02-2008, 09:51 PM
URX111's Avatar
URX111
URX111 is offline
Thumbs up Thanks Again For Your Responce ! ! ! !
I'll try it on Sunday.
TNX Paul
Old 10-05-2008, 03:34 PM
URX111's Avatar
URX111
URX111 is offline
Ijust checked & i HAVE AN "OPEN" diff.
Is Valvoline 80W-90 Dura Blend OK to use?
twall_SD250
1999 to 2016 Super Duty
30
06-16-2016 08:49 PM
wirelessmike
06-30-2015 12:29 PM
Gibby55
05-26-2011 01:49 PM
86stepsideF150
Oil & Lubrication
12-08-2010 04:10 PM
wgm114
13
11-19-2007 02:30 PM
Quick Reply: How to Change Rear End Oil?
