72' F350 antenna plug??
I ordered a plug from dennis carpenter (pic 1) but got one that doesnt fit where I pulled the antenna from (pic 2) what you see is a 95' F350 antenna wire which has its plug attached to the wire (doesnt fit the 72' hole so will cut off) I think the plug they had the antenna through is just a body plug they put a hole in. Is the dennis carpenter one correct, if so where is this plug at??
Todd
Todd
I ordered a plug from dennis carpenter (pic 1) but got one that doesnt fit where I pulled the antenna from (pic 2) what you see is a 95' F350 antenna wire which has its plug attached to the wire (doesnt fit the 72' hole so will cut off) I think the plug they had the antenna through is just a body plug they put a hole in. Is the dennis carpenter one correct, if so where is this plug at??Todd
B5A18912A .. Grommet, Antenna Lead In Seal / Fits (among others): 1970/72 F100/750.
I suspect you want the following:
C7TZ18A908A .. Grommet, Radio Antenna Cable / Fits: 1967/72 F100/750 only.
The following Ford obsolete parts dealers list this grommet. I do not know if DC has it, or not.
Green Sales in Cincinnati, OH has 48 = 800-543-4959
Miller Obsolete Parts in Binghamton NY has 1 = 800-546-7278
Parts International in Farmers Branch TX has 2 = 888-727-0418
madsonp
05-20-2017 05:51 PM
Rush117
47
06-16-2009 08:16 AM
wrekinskin
04-03-2003 04:48 PM
