Instaslling a 460 crate engine
Old 12-05-2008, 06:29 PM
Luis Astrain's Avatar
Luis Astrain
Luis Astrain is offline
Mr. Dave - FTE Moderator,
My name is Luis Astrain, I need some advise on the 460 & I was woundering if you could help me on my journey? I have a 1972 Ford / Short wheel base / F-100.
Thanks,
Waiting on reply
Luis Astrain
337-288-3311
Old 12-06-2008, 08:38 AM
chaser1602's Avatar
chaser1602
chaser1602 is offline
Thanks,
Waiting on reply
Luis Astrain
337-288-3311
I dont know what year the first one was made but ford put a 460 in a 79 f250 c/s. From 65 to 79 the frames are the same.It will be mostly a bolt in swap if you find a donor truck with that setup
And look in the article/spec section in the start up sect
Old 12-06-2008, 12:43 PM
matejcekautoworks's Avatar
matejcekautoworks
matejcekautoworks is offline
ya know, i might just have the perches your in need of to do that swap,maybe even the mounts, let me know.
Old 12-06-2008, 07:53 PM
garbz2's Avatar
garbz2
garbz2 is offline
You need the engine mounts, the perches and the isolators specific to the 385 engine in a seventies truck. Or purchase an aftermarket set of mounts.
You also need a 351M/400/429/460 manual bell housing or a C6 Automatic with the same pattern.
A new radiator will also need to be sourced if the truck was a six or small block V8.
Garbz
The swap can be made with all ford parts if desired.
luismadrigal
27
02-07-2016 09:10 PM
wtlcruiser
1978 - 1996 Big Bronco
08-27-2006 08:04 PM
luis2171
05-28-2006 11:31 PM
wtlcruiser
03-07-2006 02:26 PM
Luis_3
08-12-2002 02:38 PM
Quick Reply: Instaslling a 460 crate engine
