Fan nut removal??
Fan nut removal??
Digging into the water pump replacement and actually forgot to try & remove the big nut that holds the fan on until I had removed the serp. belt and the tensioner and idler pulleys (dummy) is there any hope of getting it off without temp. re-installing the items to help hold it?? I understand there is a special tool available but haven't inquired about it yet so I don't know how it works. (Late 1999 7.3) Thanks!
on
i pulled 1 of the bolts holding the fan about half way out and stuck a big screw driver in there and let rest against the AC pully and with a big pipe wrench i loosend the the nut...i did do this with the belt on... another option is take a old surp. belt and put it around the pully and twist a piece of square stock in there to hold it..kind of like a filter strap wrench...
Well, My closest AZ store has 2 fan removal tool kits for rent and neither is complete, I guess that the folks that rented them kept the size for the 7.3 fan nut, and the folks at AZ didn't catch it when they were returned.
I'm headed by the other AZ store later today and will check there then if that fails I will find something to improvise with.
Just use one of these...
Along with one of these...
And strike the handle of the wrench firm and quick, and your troubles will be behind you.
Stewart
