snapped like a twig...
09-15-2008, 02:14 PM
on
This what happens to a D44 with 40" ltb's! Oh well, easy fix and thought i would share some carnage shots. Enjoy.
Also i am thinking that the d44hd axle shafts are the same as non-hd axle shafts. Am i correct? Just wanted to make sure before i tore my spare axle apart. 18 spline outers and 30 spline inners.
09-15-2008, 02:22 PM
You said 40's and D44 in the same sentence!
Bwah hahahahahahahahaha!
Seriously, I thought you SAS'd the beotch with a D60?
If not, then it's time to!
09-15-2008, 04:32 PM
Street Queen to the extr3m3
as did i, thought it was sas with the 60, if not, either swap to 60 or go chromo. I think nick (quadzjr) is running 44" tires on a chromo 44.
09-15-2008, 05:16 PM
From what I have seen, the only difference between a D44 and a D44HD is the "HD" They use the same stuff.
By the way, nice work
It really ripped the caps right out. Where you turned or going straight?
09-15-2008, 05:26 PM
on
I'll never put a 60 in it. Chromos are in the future though when i get the money it.
09-15-2008, 05:28 PM
on
Quote:
Originally Posted by
teds74ford
I was actually going straigt when it snapped. I was going across a section with alot of ruts though, thats what caused it. It only lasted the first pass through the mud, not even half way. Maybe 15 yards.
09-15-2008, 05:35 PM
teds74ford
i thought there was a u-joint difference,
also
ibleedblue: why wouldnt you go with a 60?
09-15-2008, 05:51 PM
Truckin4life
lol i was thinking the same thing!
-cutts-
09-15-2008, 07:37 PM
teds74ford
Nope, the HD was 8 lug and bigger brakes IIRC.
09-15-2008, 08:41 PM
also when you drop a d44hd on your head, you get the hd imprint also along with the 44.
09-15-2008, 09:05 PM
The older closed knuckle 44HD's had bigger u-joints. The open knuckle are all standard 44 sized stuff.
09-15-2008, 09:07 PM
on
A 60 is not worth the time and work now that i already have the 44 in. Chromos will get me threw.
09-15-2008, 10:13 PM
Thats what i was thinking... I thought you ment you wouldnt go with a 60 to begin with....
Yea having to do that work over again would suck!
09-15-2008, 11:12 PM
on
Thats insane. Makes me glad I already have a D60.
09-15-2008, 11:27 PM
Chromos break too... Buddy of mine found that out the hard way....
