Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-12-2008, 05:05 PM
Black Cowboy Black Cowboy is offline
Garage is empty, add now
Black Cowboy is starting off with a positive reputation.
Transmission Fluid as fuel?
One of the other technicians at my shop was talking to a Ford technician last week and he said that he's (Ford Technician) been using old tranny fluid instead of diesel fuel. Has anyone else ever heard of this or even tried it? I'm curious to know some results. Thanks
__________________
Jason
  #2 (permalink)
Old 09-12-2008, 07:51 PM
Wieckster Wieckster is offline
Wieckster is starting off with a positive reputation.
I dont think I would put it in my truck That motor is pretty expensive to replace if it doesnt work
__________________
CHAD
2001 F250 4x4 Lariet Extended Cab,Kwik Filter,5" Exhaust Straight-piped,Auto Meter Gauges,285's,WW,CCV,BlueCPS,Remote Start/W
alarm,8.2 BOSS VXT-Plow,Cool Pipes,Bilstein shocks,203 t-stat,ext coolant filter,Heated W/ turn signal mirrors.Clear headlights with LED's
  #3 (permalink)
Old 09-12-2008, 08:04 PM
lol, believe me I know. I'm currently putting a new motor in my F350
__________________
Jason
  #4 (permalink)
Old 09-13-2008, 10:17 AM
royzell royzell is offline
royzell is starting off with a positive reputation.
I've done it, in my IDI as well as several MB's. My MB mechanic recommended it as a way to clean the engine. On this forum, we always talk about using ATF to fill the fuel filter when changing. I've never run it straight, it was always mixed with diesel.
__________________
88 F-250 ext cab, 7.3, C-6, 3:55, 4WD, - sold
84 Mercedes 300SD turbo-diesel(parts car also)
93 Honda Accord
77 Chev Class C Motorhome
and other rusty or rugged parts vehicles...
  #5 (permalink)
Old 09-13-2008, 04:03 PM
Quote:
Cool, thanks for the info. does it make the truck run any better when mixed with diesel? Just curious that's all.
__________________
Jason
  #6 (permalink)
Old 09-13-2008, 05:46 PM
I can't tell any difference.
__________________
93 Honda Accord
  #7 (permalink)
Old 12-09-2008, 07:11 PM
magneto259 magneto259 is offline
magneto259 is starting off with a positive reputation.
I just read about a guy using atf in his 03 excursion and hes put over 10k on it and said it runs fine. He mixes it 90% atf and 10% diesel. I heard that newer atf has friction modifiers in it and will damage the injectors. Is this true? Or does the used atf lose its friction modifying properties when it's used? I've thought about running it but I don't want to ruin my truck. There was a article in diesel powermag this month on it.
  #8 (permalink)
Old 12-10-2008, 01:56 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Any used ATF contains submicrom metallic particles that will eventually destroy cylinder walls, rings, injectors, fuel pumps, pressure regulators, etc.
USE AT YOUR OWN RISK
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #9 (permalink)
Old 12-10-2008, 08:08 PM
Thanks for posting this lil' tidbit of info because I was curious if the little metal shavings would cause any problems. I think I'm just gonna play it safe and continue running just regular diesel fuel. I just recently put a new motor in my truck and definitely don't want to do it again.
__________________
Jason
  #10 (permalink)
Old 01-08-2009, 08:32 PM
TxFordGuy TxFordGuy is offline
TxFordGuy is starting off with a positive reputation.
I understand about the metal particles, but if you were to filter used oil down to 5 micron or less. why would it hurt the engine when the stock filter is only 7 -10 micron. anything 5 micron particle in regular diesel fuel is getting past the stock filter
__________________
2002 F-250 Lariat 4x4 CC, 4" Magnaflow SS Exhaust, Wix 6637, Petes Cover, DP-Tuner
  #11 (permalink)
Old 01-08-2009, 11:57 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
Quote:
I was thinking about the same thing, only I would filter it down to 1 micron absolute. McMaster Carr sells a 1 micron absolute sock filter pretty cheaply. Pump it through that then mix with diesel.
I have a hard time seeing how anything smaller than 1 micron - even metal particles - could do much if any harm. I mean 1 micron is 1/1,000,000th of a meter, right? Thats like .00039" - less than 0.4 thousandths (4 TEN thousandths) of an inch. There aren't any tolerances anywhere in the engine - or the fuel system - that are anywhwere near that tight.
One other point that people seem to ignore is that the fuel you buy has got to have metal particles in it too. All the pumps, tanks, piping, valves, nozzles, etc. that the fuel passes through between the refinery and your tank it has to pick up some metal shavings and dirt. That's why the fuel system has filters to start with, right?
Of course a magnet to catch even sub-micron sized particles of iron-based metals couldn't hurt. If anything would do any harm it would be the steel and iron particles. Just because they are so much harder than the brass and aluminum particles.
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #12 (permalink)
Old 01-11-2009, 12:41 PM
Phydeaux88's Avatar
Quote:
They act as an abrasive and gradually wear thing like injectors and fuel system components. A magnet will not work because the clutches in the transmission, which wear during use, have non metallic and/or noe magnetic components.
__________________
  #13 (permalink)
Old 01-13-2009, 07:56 PM
Knotwild Knotwild is offline
Knotwild is starting off with a positive reputation.
I would never use it personally, but I did see an article on ATF as fuel in Diesel Power magazine (I think it was DP, but it might have been another diesel magazine).
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #14 (permalink)
Old 01-15-2009, 10:42 PM
j250hd j250hd is offline
j250hd is starting off with a positive reputation.
I have a 95 stroker and my cousin has a 97 stroker. We have run thousands of gallons of used tranny fluid through our trucks. No problems to speak of did the math on fuel bills for last year and combined we saved 9,682 dollars on fuel! That pays for two motors and a couple grand left over if we did have to replace it. It was nice to keep that money in our pockets though!
  #15 (permalink)
Old 01-16-2009, 12:21 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
I too have burned around 3000 gallons in my '02 F350 Power Stroke with no problems. I have on my odometer 240,000 miles. I do not burn used tranny fluid but I do burn used hydraulic oil and ATF drained from air compressors. I have even burned synthetic compressor oil. I never calculated how much money I have saved but I am sure it mounts up fast.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
Tags
1986, 300sdl, aluminium, automatic, bakersfeldca, diesel, dispose, fluid, forum, fuel, mercedes, motorhomes, oil, particles, transmission, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
