1997 Explorer Lowbeam Headlights
Old 09-14-2008, 08:41 PM
Texas162001's Avatar
Texas162001
Texas162001 is offline
Unhappy 1997 Explorer Lowbeam Headlights
I have a 97 AWD 5.0 v8 explorer, the headlights started off with just the driverside headlight did not work, but then my Dad "fixed it temporaroly" to get it passed inspection not sure exactly what he did but it worked for about a month then all of my lowbeam lights went out including fog lights both my high beams still work. we have changed to headlight on/offswith, High/low switch. the message center in the console says my low beam light are working just fine. Please help.
Old 09-14-2008, 09:47 PM
firepop5's Avatar
firepop5
firepop5 is offline
There is a "lamp out module" that controls headlight messages in message center. Current passes through it on the way to the headlights. Google "explorer lamp out module". If it is faulty, the headlights won't work. The module is in the console beneath the message center. You can take it out and open up to see if some of the soldered conntacts have broken. If so, you might be able to resolder them. If not, replace module about $70 from ford.
rangerbait
6.7L Power Stroke Diesel
02-13-2016 06:03 PM
Larry Wall
05-19-2015 10:09 PM
mudslinging79
1978 - 1996 Big Bronco
05-07-2015 09:46 PM
20Mike
1997-2006 Expedition & Navigator
03-11-2015 02:04 PM
martinraz
08-12-2014 05:32 PM
Quick Reply: 1997 Explorer Lowbeam Headlights
