snorkle info
snorkle info
[updated:LAST EDITED ON 12-Mar-02 AT 09:15 PM (EST)]im thinking about putting a snorkel on my 75. if i can ever get the curage to cut the passenger fender. i think that would be the easiest way to run it. my buddy is also wanting to put one on his 85. i guess the only way is to get a closed air cleaner and cut a hole. and route it up into the air.
'75 F-100 4x4, 4" lift
16x38.5x15 super swamper TSL
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
390 w/ cam,headers,
snorkle info
Orange peel, I've been giving this a lot of thought, too. I have a 460 with the stock air cleaner and was thinking of connecting to the rectangular horn on that. Instead of punching thru the fender, I was gonna run a duct into the glove box or in the cab somewhere. But you could do it either way.
My main concern is with the dust and not the water. That's why I want it in the cab.
Kevin K.
Kevin K.
snorkle info
Keep in mind that if you are getting deep enough to need a snorkel you'll need to seal up and waterproof all your electrical components especially your distributor and coil, and waterproof your oil cap and dipstick. Sparkplugs might also need to be sealed around the edges, but I'm not sure.
The Law
The Law
snorkle info
Had a 71 that was used only in mud bog /drags .I found a old air cleaner that had the 5 1/8 opening and had two inlets and hooked dryer vent hose to them and ran them inside the cab.You need to make these hoses so they will stay stretched out or they will collapse.I Used coffee cans to connect at firewall.It worked good .With a sealed distributor it would run under water.Also ran all vent hoses into cab.
Larry
Larry
snorkle info
lshort, we need to talk man. I just bought a weekend warrior/serious playtoy that i want to run exclusively in mud bogs/drags in indiana (primarily). i haven't had much time to check it over, i bought it in va and drove it home and then came back here to college, but i'm pretty sure after i fix everything that's broken it'll be ready to roll. i wondered if you could offer any advice on how to set it up, like snorkel, etc., or if you had any inside info on what works and what doesn't. oh yeah, if anybody knows anything too, holler. thanks a lot guys!
take it easy,
Luke.
take it easy,
Luke.
snorkle info
ok, i havent given this idea much thought since i last read this post which apparently was in march. but now that i have my exhaust running up and over my cab i think im about ready to run the snorkle, from reading the replies this is my plan: im going to get the stock air cleaner housing that has the hose on it that ran to the grill, im going to run that to the passenger side of the truck, cut a hole in the side, use dryer tubeing to run it up to the roof and then just connect a K&N to that.
but how do i keep the tube tight? i saw the coffee can idea but i didnt really get it. thanks for any input
snorkle info
i've heard of people using exhaust tubing as well. it would probably be lighter than the pvc, and the connections wouldn't be so obvious. not sure on the pricing, but look at some 4" pipe and see how that tickles you.
K&N filter do NOT let in more dirt than a paper filter. their job is to keep the dirt out. and if your filter is up in the air for all the world to crap on, you'd have to replace a paper filter every time it rained/got muddy/hit a bird/tree..... you get the idea.
i've thought of snokeling my Scout, but i'm not too keen on choppin the fenders...
Jared
Jared
