Engine Coolant
Engine Coolant
Did a search, didn't really find an answer. I read that a 2004 4.6L F150 takes "yellow" colored Engine Coolant 50/50 with distilled water. I picked up some Prestone Coolant and also some distilled water to mix 50/50.
I also read NOT to use "green" colored coolant. What is this coolant that I bought considered...to me it looks yellow, but it could also pass for green maybe.
http://www.prestone.com/enlarged/ima...eAntiCool3.jpg
Cory
Cory
it seems to mix with everything...we have been using it at my shop for 6 months to top off reservoirs and havent had any comeback coolant issues.
we use this for complete repairs...ford compatible coolant
Motorcraft gold or Zerex G-05
...is what you should be using. The Ford gold coolant is basically used by *some* other brands and is generically called G-05. It is a "HOAT" formula--hybrid organic acid technology.
G-05® Antifreeze/ Coolant
The Prestone stuff is probably OK but does NOT meet Ford warranty requirements and will require more frequent changes. If you want to maintain the original 5 year change intervals, you should be using Motorcraft gold or the G-05 stuff.
I looked into this stuff a while ago and you definitely need a decoding ring to figure it all out. I am also using the G-05 in my '91 BMW 318is because it is virtually the same as the BMW factory stuff.
NEVER use the orange GM Dexcool type stuff under any circumstances.
edit--just looked at AzBlueWolf's link for full changes, and he is using the G-05 for full changes as well. This seems to be the best choice for Ford, Chrysler, and some other brands like my BMW....
George
George
Ive never seen the G-05 stuff at a local parts store. The forum sheds light on many things for me!
The prestone coolant I mentioned is not okay by Ford? I thought it met all the requirements, but I could have missed the boat. I was only asking if its okay because I've got 2 brand new jugs of it in the garage, and I read that "yellow" coolant is supposed to be used in my 2004 4.6 truck. I will continue more research.
Cory
Cory
* The new Prestone® 50/50 Prediluted All Makes All Models Extended Life Antifreeze/Coolant formula should only be used to top off the cooling system. For a flush and fill, motorists should use the full concentrate formula offered by the brand to ensure the right mix of water and antifreeze concentrate.
the whole story...Preston Antifreeze
I found G-05 at Pep Boys....
Cory
Cory
It's pretty clear from the Prestone info on their website that it does not meet Ford warranty specs.
George
I found two good pages of specs...they seem pretty close in "specs"
Zerex
http://www.valvoline.com/products/zerexg05.pdf
Prestone
Prestone Antifreeze/Coolant Product Specifications
Zerex
Prestone
