Whats The Best Way To Change Out Coolant
I need to change out the coolant. A guy at work suggested quick lube, said they can flush out the system. He mentioned that I need to tell them to add the additive. I aint to sure about taking my truck to quick lube???? What should I do, What is the best way to clean the system out? I dont have a filter.
1 Empty the radiator
2 pull the drain plugs from the side(s) of the block. Put em back in.
3 Add water & a cooling system cleaner. Drive it for 5-10 miles. let cool and drain
4 repeat step 1-3 with water only
5 Drain again....add coolant and additive.
That's the best way, but not the only way
BTW: The plugs in the side of the block are a PITA to get out. and may require a special square socket, 5/16 IIRC
One is behind the starter.
That wouldn't be a bad idea. Keep it on hot.
The more times you flush it the better. I keep flushing till the "water" comes out clear, as in no green or red. There's no need to completely drain the block if you do it this way. All you're doing then is giving yourself a chance to burn yourself a few times repeatedly.
What do you guys think about the preston flush set up that lets you hook up a garden hose to the heater hose? Might make it easer that doing the flush and repeat thing. http://www.prestone.com/products/fla...cessories2.swf
I have one of those Prestone kits on my little commuter car. It worked fine, but you have to do it someplace that a big mess on the ground is acceptable. I'd try to catch all the coolant you can first and dispose of properly if possible. I doubt your PSD would ever warm up though with fresh cold water plumbed into it.
Sounds good and bad. Good that it might get some gunk that the coolant flush might miss and bad because if you cant flush it all out what will it do to your engin?
That's some very corrosive stuff. I would not use it. There are many coolant system cleaners that will do the job...but none of them will get all the crud out of the bottom of the water jackets. The only way to get it out is to remove the drain plugs on the side of the block and flush it with a garden hose. (PITA) You would not believe how much rust, sand and calcium that comes out.
There is a water flow control valve that you can add to a heater core line. It will make your AC work a little better.
Look here:
http://www.dieselsite.com/index.asp?...PROD&ProdID=21
