2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
5th Gear?
Old 08-23-2008, 08:42 AM
swflagn's Avatar
swflagn
swflagn is offline
5th Gear?
I'm getting ready to buy an 08 Expy EL. I'm getting the HD Towing package for towing my boat (3000lbs). My question....Is there anything you can buy/do to keep the transmission in 5th gear while towing? It seems to me that this gear would be perfect for the highway.
Soon to be a former Suburban owner.
Old 08-23-2008, 10:02 AM
SemperFiDevilDog's Avatar
SemperFiDevilDog
SemperFiDevilDog is offline
Keep it out of OD
Old 08-23-2008, 10:29 AM
chuck s's Avatar
chuck s
chuck s is offline
If you want massive fuel consumption and high engine RPM turn the OD off and the transmission won't shift higher than 4th. Why would anyone do this?
I tow my 5000 pound camper with OD on and she runs at 1800 rpm in 6th gear. Sometimes she'll down shift to 5th and less down to 4th. No point in running 4th gear all the time if you only need it 10% of the time.
HD Towing package gets you about 9000 pounds max capacity. 3000 pounds won't be much of a bother at all, our 5000 pounds barely is. I've monitored transmission and engine coolant temperatures and only trans temp shows any rise from normal driving and that by 10° or 15° at most. Engine coolant remains below 200°.
-- Chuck
Old 08-23-2008, 10:59 AM
swflagn's Avatar
swflagn
swflagn is offline
Chuck, I do not want to tow in 4th. Just want to know if there is a way to keep the tranny locked in the first OD gear, fifth.
Old 08-24-2008, 01:57 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
There is no way (currently) to do that.
Old 08-24-2008, 09:53 AM
chuck s's Avatar
chuck s
chuck s is offline
The reply to the original message suggested turning OD off. That'd make you run in 4th gear. As noted there's no way to lock out 6th gear. Nor is there any reason to lock it out.
-- Chuck
GSDSROK
08-12-2014 10:36 PM
mtbrewr
Fifth Wheel & Gooseneck RV Towing
07-12-2008 10:59 PM
stangclassic66
30
08-13-2007 07:30 PM
chimchim
1997 - 2003 F150
24
07-27-2007 06:32 PM
sandiegogreg
Toy Hauler Towing; Fifth Wheel & Bumper Pull
02-10-2005 02:38 PM
Quick Reply: 5th Gear?
