Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-19-2008, 07:06 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
Garage is empty, add now
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
I had a thought,now what do you all think?
I was doing some thinking the other day and would like to know what you guys think.My dad was in the water treatment buisness for about 20 years therefor I got to thinking about the equiptment and material that was used to neutralize acidic water. the material was basicly crushed oyster shells and that is basicly all calcium. this substance would raise the PH of water from anything from a 4.5 up to a neutral 7.0 just by passing through it. that being said here's my question.. Would this stuff work on wvo to bring up the PH from high FFA. would it have any adverse affects on the oil or Biodiesel production. I plan on trying this by perculating the oil through a mixture of calcite and this oyster shell material. I want to try this due to the crappy oil that I've been getting lately just as another option for high titrate #s. I do know that the material would desolve into the water to raise the ph and then was filtered out leaving ph 7.0 water. I wanted to get some feedback as to what you guys "fabman" thought about this and if you think it will work. thanks for any info and I'll post some results once I try it this weekend. the material is about $50.00 for 50 pounds but it lasted for several thousand gallons of water, maybe it will work for WVO.
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
  #2 (permalink)
Old 08-20-2008, 09:07 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Oyster shells contain calcium carbonate which is an ionic compound so it is soluble in water. When it dissolves it forms Ca(OH)2 a base which raises the ph of the water solution.
Calcium Carbonate is not soluble in oil so it cannot raise the ph.
Good idea but the chemistry is not right.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
