Anyone ever "bob" a styleside long bed
I'll second GreatNorthWoods. Just bobbing the bed and leaving the axle in place would not look good imho. On the tv show trucks, they did this on a chevy, first they shortened the frame then they cut the bed vertically at the front and back cut out a foot or so pushed it all back together and welded it all up. Looked like quite a bit of work to me. I would definatly cut the frame to shorten it and get a stock shorted.
Doesnt seem like it'll be lot of work to take 6inchs of the bed and frame. I was gonna mess around on photo shop to see how it'll look before I break out the sawzall. Has anyone here moved their rear axle to accomodate a short bed? I would rather do that. however I dont know where I might find a styleside shortbed located in the northeast.
on
1 Post
I would suggest that if you are planning on shortening the frame (depending on your personal welding skills) get a professional welder to Z cut the frame section and have him fish plate the cut to restore the rigidity back to that part of the frame. This is not something an armature welder should be doing and in the long run you will be much happier with the end results.
As for cutting the bed. Measure twice.....cut once.......
Or in the case of making my truck into an extended cab, measure twice, measure a 3rd time, think about cutting, measure 2 more times, then start to cut... measure half way through, finish cutting...
And I'll also second that if you need to shorten your frame to use the Z-cut and fish plates, its what I did to lengthen my F-3 wheelbase from 122 inches to 144 for my extended cab. There are pictures in my gallery, link is below
https://www.ford-trucks.com/user_gal...&albumid=19345
Later Man...
RE: "Bob"ing a long bed
Matt,
I bought a 1951 F3 back in the spring that had been 'bob'ed. It looked good enough that I didn't figure out what had been done to it until I had already bought it. You can check out the photos of my truck in my gallery. You can tell that something isn't quite right about it.
I thought about selling the truck and buying an F1 (which is really what I want), but so far all of the trucks that I've looked at need a lot more work than the truck that I have.
Right now, my plan is to shorten the frame and put a short bed on it (and new fenders all the way around because of the wheel opening issue). There are people here on this forum who have done this before and can give you good advice if you choose to go that route.
Good luck!
-Doraville
Good luck!
-Doraville
Matt,
I
Good luck!
-Doraville
I
Good luck!
-Doraville
I took a look at you gallery... Nice looking truck. Yep, the tail bobbing is noticeable, but it still looks good. I can see why you would want to change the front fenders to get a smaller cut out, but the bed issue doesn't look all that bad. BTW, bobbing that style bed is way easier than the newer ones because there is only one sidewall in the bed. As a matter of fact, it's pretty easy to make most of all the panel sections in it as well as the rear corners. It's about all flat with well defined sharp right angle bends. About any sheet metal shop can make what you need. If you are determined to go with a short bed you would probably be ahead to change the one you have. You might even be able to just move the fenders up on it.
In any case, good luck with your plans.
Later man...
