Diesel prices
Can you help me get some info on that? Can you burn WVO without going through the hole bio diesel chemistry thing?
hey guys, sorry it took so long...
if you go to The Grease Works Online Store they have the fuel lines you need to convert (necessary for biodiesel or veg. oil). The kit is $135.
To use vegetable oil, you'll also need a couple more feet of the sae30r9 hose, and some more of the ABA hose clamps (regular clamps will make the hoses leak). I put a plate heat exchanger I bought on ebay for about $100 underneath my truck, right by the tank switch area, and ran the fuel hoses so that the fuel ran through the exchanger, and coolant hose from the engine back to the exchanger, and back again. I wrapped it with pipe insulation and tie-wrapped it to the truck. Took a couple of hours, and about $250... I'll try to get some pics soon. Good luck!
Maverick, howdy neighbor! I got my truck back in May. It's still stock but I have some modest plans for her. 1st diesel doancha know. I drive like a grandpa most of the time, partly because....well.....I am one. But also cause I like being able to drive something thats a blast to drive, and I avg 18 mpg around town including my short (15mi) commute to work, doing it.
Do you have a local place you get your filters from? Fuel & air?
