View Poll Results: When/If the Spark Plugs are gonna get changed? And results
Changed Plugs in relation to a repair with breakage.
0%
Voters: 69. You may not vote on this poll
Another Spark Plug Thread & Poll
Why coulnt Ford leave well enough alone? The 302 was a great motor no problems. Got the same or better mileage as 4.6/5.4. Easily could make 250-275 hp and last for 200K. I was thinking about this the other day. Mt dads 88 f-150 4x4 got 18 mpg and would probably out pull my 4.6 equipped truck that gets 17-18 mpg. Sorta random but I think a good point.
I changed mine at 51,000 miles. They all came out with no problems, installed the new plug design that will not break. I plan on having this truck for the long haul and I did not want to wait until 100,000 miles and then have some break.
After 35,000 - 40,000 miles the plugs
are worn and you can lose up to 5 HP or more. The reason why a lot of the auto makers are claiming that these plugs do not need to be changed until 100,000 miles is so they can show a low cost of ownership which looks really good on the JD Powers report.
When I changed the plugs I noticed a difference immediately.
Wife has a 2005 Explorer with the 4.6 2V old design. But head has more threads and Ford used antiseize on the plug threads! At around 40,000 miles the cop wires started cracking and setting codes. She had the dealer replace them and they convinced her the plugs should be replaced also, So she had them do the plugs also. As "justification" for changing the plugs they gave her the "worse worn" one. Needless to say it was in good shape still at 40,000 miles. The platinum puck still had good life left, the plug color was spot on and clean and the plug gap was not much larger than specs for new plugs. Could it have gone to 100,000 miles? Yes, with her style of driving and the rate she piles on the miles. But most likely with loss of mpg and power. My 2002 F150 with the 4.6 but with the 3 thread head would probably blow a plug or rust the plug so it's difficult to remove. After almost 7 years I've only gone 38,500 miles. Last Fall I loosened the plugs, didn't remove them, but retorqued them to factory specs. Come next Spring or Summer I'll change them for new Motorcrafts, put antiseize on the threads and torque them to factory specs. I broke them loose last year because I was afraid they could seize if left for too manny years undisturbed.
Whimsey
Whimsey
Well took my 05 F150 5.4 to the dealer today for the brake recall. I asked the service manager about the cost of changing the plugs and he said " why would you change them now the go 100,000 miles" I meantioned about reading on here that they build up with carbon and break. He said that they have NEVER broke any and the cost with plugs would be $160.00. he said that there is a T.S.B out on them but he nor any of his mechanics have ever seen one break. He has an 04 that he waited until 1000,000 miles and the came out, he said just don't get in a hurry and snap them off. So I will wait and see what happens.
9/10 of them were NOT early plug changes......check the old threads...most of them were at 75000 miles or more...
#28
ok, this was pathetic. I spent 2 hours searching through the 2004+ F-150 Forum. I went from present day to spring of 2005. Used the search terms or "broken" "spark" "plug" in the 2004+ F-150 forum only.
There is a really interesting thread from 2005 that is 5 pages long...actually, there a several 5/6 pagers. Some really imaginative ideas for removing broken plugs. Highly recommend anybody who breaks one read that thread.
The list below is the people who have posted about changing their plugs and the results.
I predicted 9/10 changes result in a breakage. Boy was I wrong. In other threads I guessed it's a 50/50 crapshoot. Should have listened to myself. If you account for all the broken vs. the non-broken in this forum alone, # is 25 breaks vs. 20 non-broken. I'm too geeked out to do a similar search for the Superduty 5.4 forum and the Expy forum. Probably find similar results
so, for the F-150 it's a 60% chance you'll break your plugs.
Broken at 100,000+ miles
Broken under 100,000 miles
Not Broken
Broken, Don't know the mileage
I stand by my stance I've always had on this issue. Wait until 100,000 miles. Numbers don't lie. 50% or worse chance of breakake is just scary.
1. matt1304 - 6 broken at 110,000 miles
2. sawsalesman - 1 broken at 110,000 miles
1. bigGmechanic - 3 broken at 91,000
2. twinsdad98 - 2 broken at 54,000 miles
3. MBBFord - 5 broken at 100,000?
4. mkoser - 2 broken at 51,000 miles
5. m825smoke - 3 broken at 75,000 miles
6. patmanb - 7 broken at 51,000 miles
7. dadirtydog - 2 broken at 55,000 miles
8. 1-bigmac - 2 broken at 34,000 miles
9. gmc805 - 1 broken at 85,000
10. wasa4243 - 5 broken at 78,000
11. grnmstr - 7 broken at 90,000 miles
12. wesFX4 - 1 broken at 50,000
13. FX4Jim3 - 1 broken at 47,000
14. matt983 - 1 broken at 78,000 miles
Not Broken
1. CMOS - 41,000
2. JimTex - 65,500
3. bigdogk9 - 29,000
4. 2004 xlt 5.4 - 47,500
5. biggdawg900 - 52,000
6. mitch 150 - 70,000
7. motown - 43,000
8. ryan50hrl - 23,000
9. DMAC66 - 110,000
10. DRM2004 - 41,000
11. BrianFX4 - 65,000
12. stratus225 - 27,000
13. jeffrey101965 - 25,000
14. 73mach1 - 17,000
15. exiled - 45,000
16. kgousie - 30,000
17. t lindemann - 12,000
18. golflug - 28,000
19. black04FX4 - 20,000
20. jpdadeo - 16,000
2. JimTex - 65,500
7. motown - 43,000
9. DMAC66 - 110,000
15. exiled - 45,000
1. mrdemoss - 1 broke
2. kevinAH - some posts say 3, some say 6
3. slf06f150 - 2 broke
4. boots6868 - 1 broke
5. e43020 - 2 broke
6. cligget - 2 broke
7. mikepatterson
8. obx h20 boy
9. cavtrooper06 - 1 broke
5. e43020 - 2 broke
7. mikepatterson
8. obx h20 boy
#29
factoring in the 9 unknown mileages and assume they were <75k (figure 15k/yr mileage, so average 2004 truck would only have 60-70,000 miles)...that gives you 18 of 25 breaks under 75,000...or 7/10 breaks occured below the 75,000 mile point
<90,000 miles with breakage (>90k is too close to 100K, therefore can't "truly" be considered an early change)
12 of the 16 breakages with known mileage occured under the 100k mark
and if we assume the 9 unknown mileage ones were <90,000 miles, that makes a possible 21 of the 25 breakages under 100,000 miles...or an 8/10 chance that if your plugs break, it will be under 100,000 miles based on FTE user posts
I know, we could assume the 9 unknownrs could be over 100k...but realistically, they won't be. and I fully admit to not being a staticions (sp?)
#30
