Safe Jack Stand Locations on F-250?
Does anyone have a diagram of safe jack stand locations on a 99 F-250 4x4 V10? I realize this sounds kind of an obvious (total noob) question, I'm thinking to just put them just under the rails - front and back.
I'll be jacking the rig up at the appropriate points on the rig - but I need to place a jack stand at other locations so I can do some brake work.
Thanks in advance.
Thanks in advance.
Welcome to FTE. If you're looking for pictures of where to place the jack, you're best bet will probably be your owners manual. If you don't have one, you can download a copy here for free https://www.fleet.ford.com/maintenan...ls/default.asp
Otherwise jack the axle up and place your jack stands under there. If you try and jack the frame, you'll need a jack with a lot of travel to accommodate the suspension.
P4IN COMM4NDO
16
09-26-2016 12:02 PM
