add a leaf ???
add a leaf ???
Ok so yesterday my parents gave me money for my birthday for a leveling kit. I thinking im going to go with the 3 inch front spacers and add a leaf in the back. Well my question is here the add a leaf all the ones I see have a center bolts and no clips. Shouldnt they come with new clips to accomidate for the new leaf spring? I was asking my buddy on what to do cause I never did it and he has some experience in this. But I just wana see what you guys have to say. Need help. Thanks guys in advance
yes, cancel that order. do a search for cv angle shots with the 2.5"
the 2.5" puts the angle pretty wicked IMO. but since I don't spend alot of time offroad, it's acceptable. that extra .5" of angle is pretty extreme.
also, the 2.5" puts most trucks dead level, and some even go nose high. I know this isn't a concern since you are adding an AAL, but it's another thing to consider
if it's too late, then so be it. you can always guinea pig it for us
I got bored (it's a slow night out here) and went took pics of my CV joints with the 2.5" installed.
I didn't snap pics of the OEM angle before the install, so I drew a little green line to simulate the OEM angle. Hope it makes sense what I'm trying to get across.
As I said, the 2.5" kit puts the cv angles at a pretty good angle, but IMO it's fine for normal 4x4. Between the extra .5" of angle and the nose high characterisist, I think the 3" is too much.
current CV angles
OEM CV angles
OEM CV angles
I installed the 2" leveling kit up front and it went nose high. I installed the AAL in back and now it's just right. Just beware of the leveling kits. Mine ended up about 1/2" higher up front than was supposed to end up. In my opinion anything bigger than 2" is too high. If I hadn't planned on the AAL, I would've probably prefered a 1.5" kit up front.
